Exclusive: 2012 MY Prius - Changes and Additions
Discussion in 'Gen 3 Prius Main Forum' started by Danny, Aug 26, 2011.
  1. Trollbait
    12,831
    Matte finish seems to be the in thing for the real high end cars and custom paint jobs. It requires more care, so I don't see it coming to the regular car majority even if price wasn't an issue.
    There won't ever be an independent rear suspension on the Prius. It's rare on regular wagons and hatchbacks do to space issues. The battery will have to downsize before Toyota considers for the Prius.
  2. Tideland Prius
    16,681
    It's a very dark blue, almost black under cloudy conditions. Check out the 2011 Corolla (as it comes in Nautical Blue) as well as the 2009+ Matrix. The 2006-2008 RAV4 and 2007-2009 Scion tC also came in Nautical Blue.
    Ford's system will put the vehicle into position (so it will move forward and centre the vehicle). Toyota's system only gets you in. You have to pull forward and centre the car yourself.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    My wild guess is that perhaps Toyota didn't have time to or didn't feel it was worth the expense of porting IPA to the new Entune hardware, which might have a totally different software development platform/environment.
    I do like the HUD becoming available though...
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    So basically it does the pre-support system part for you? I prefer to skip the pre-support system entirely as it takes too long. Just pull up as normal, shift in reverse, hit the parallel button and okay it once you see the green lines. Much faster that way.
    I think it's just a cost saving measure in order to keep the same price point. Something had to go in order to get HUD in (probably due to popular request) and it made sense for them to get rid of IPA of all the AT features.
  5. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    When will the 2012's be available for purchase?
  6. Tideland Prius
    16,681
    Pretty much. I don't know if Ford has a non-support version like we do (or whether they MUST hit the button every time).
    Yeah once you know where to position the car, it's faster to just press the onscreen button and then ok rather than crawl around in Pre-Support mode.
  7. Zanrok
    Zanrok Casual Prius Lover
    181
    30
    Reno, NV
    Thanks for the information! Now the two big questions I have...
    When will the 2012's be available to buy?
    And...
    How much will they cost?
  8. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Toyota (Build Out Final Order Start Up Dates)
    ProductionDate: Dec/2011; Delivery Month: Feb/2012
    As far as cost, who knows, Prius may see a price increase similar to the 2012 Camry!
  9. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Fits OK in the CT200h, which has fully-independent rear suspension.
    The Ford Focus has had fully-independent rear suspension since it launched in 1998. Ford have a layout they call 'control blade' which is compact and made from pressed steel parts, so it's cheap to assemble as well.
  10. Tonic
    Tonic New Member
    142
    Montreal
    Im sure Entune for Canada wont be available on all model and why they are releasing 2012 only in Feb 2012? I mean why not having them already in stock?
  11. Zanrok
    181
    30
    Reno, NV
    I am bummed about the release date as well... But my guess is that due to the tsunami... everything from Toyota has been pushed back.
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    that site is constantly wrong when it comes to retail delivery.... for instance, Camry Hybrid is coming to dealers in October, while it says Jan/Feb... it might be for fleet customers only where Toyota does not allow fleet orders for first few months.
  13. cashcorn
    cashcorn New Member
    45
    dana point
    I'm really disappointed that the new level v will not be available with a sunroof. I thought this was a no brainer for the engineers! I understand the weight issue with the 17's, but how come there are so many aftermarket rims that weigh half the weight? At least allow the HUD on the level 4, then i could add the rims of my choice. Otherwise i will be waiting for the Model S.
  14. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Based on the use of the new screens in the Prius v, I anticipate that the 2012 Prius will use the screens for MID functions.
  15. ramdulari
    ramdulari Member
    153
    Wowweee!!!
    My 2010 will be sooo outdated!
    I'll jump in in another 10 years hopefully (2022 Prius?)
  16. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    How many automakers run the EPA tests and/or how many cars does the EPA certify with aftermarket rims that the automaker itself doesn't sell?
    I doubt it's strictly the weight of the rims alone but rather the mileage hit from a combination of factors (e.g. tires being heavier, revs/mile difference, likely greater contact patch on the 17" tires, difference in tire model, etc.) + hit from greater weight of the roof.
  17. Tideland Prius
    16,681
    I believe it's structural integrity as well as weight. Remember that it's both the moonroof and solar panel, not just a moonroof that they'll add.
    My friend's car with a fixed roof doesn't creak coming out of an underground parkade at an angle while mine does with the solar roof. The structural integrity is different.
  18. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I deeply hope they will not change the Instrumtent panel,because i thought it was a very good thing separating the energy flow-display,climate controlls and Nav so you can have all the info at the same time without having to circle through a menu in wich you only could display a single feature !
    It really would be a major step backwards into "old" times !
    What i do hope for is,that they will colour it !
  19. spwolf
    3,156
    440
    Eastern Europe
    well it creaks because you have layer of glass or plastic, whatever it is, on the top of the roof... vs same metal mold.
  20. babybird
    babybird Member
    117
    44
    Colorado
    I don't see removing IPA as a cost-saving issue unless they'd have to re-develop the software for it for the new system. The Prius with AT package already comes with all the hardware to support the feature, so once the software development cost has been absorbed, it costs exactly zero to add to the car, it's just a couple extra megs of programming they load into the computer.
    I suspect it'll be added back in eventually. The systems over time will get good enough that it's not a time hit to use it and we'll see it on more and more cars, so it'll have to come back to remain competitive. Whether that's within the gen 3's remaining lifetime or not is open for debate though.
