Exhaust 101?
Discussion in 'Gen 2 Prius Main Forum' started by PriusPaddler, Apr 12, 2025.
  1. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Replacing my 2009 catalytic converter. Have to adapt between the new cat assembly and downstream remaining exhaust parts.
    Should the adapter go OUTSIDE both pieces? Or outside on upstream and inside on downstream? Or something else or doesn't it matter?
    Thanks in advance.
    This is the part I bought: EPA Catalytic Converter for 2004 2005 2006 2007 2008 2009 Toyota Prius 1.5L L4 | eBay
  2. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    I will not be able to weld, will be using clamps if that helps.
  3. Tombukt2
    Tombukt2 Senior Member
    13,878
    2,521
    Durham NC
    What is the adapter You talking about the gasket that round ring What do you mean back at the other end to the cat back because that unbolted in your car? So what happened when we did this is I used my sawzall with a Diablo blade and cut the flange off and then when you put the gasket with the tapered part facing back towards new pipe. Now hold the stuff up and take a look and see if you would just be able to slide your new piece over where you just cut your flange off usually if you cut right at the edge of the flange your new pipe will slide on you'll made up at the manifold. You see it stays in okay You can tighten up the bolts at the exhaust manifold and then come back and undo your clamp and put it over your new pipe start the nuts beat it into the position you wanted in If you have a way to hold the two pieces up like with a 2x4 cut or something like that to where you want it to be then you can tighten up those two nuts on the clamp and it should grab around your pipe okay and then after you drive and see everything is okay and all that you can run it by a muffler shop and then you might not even have to get out of the car Just pull you up on the lift and take the clamp off and do what needs to be done and tack you in place. Least my guy does.
    PriusPaddler likes this.
  4. Tombukt2
    13,878
    2,521
    Durham NC
    Looks good The one in my '05 which is not on the road now is the same thing I need to take this pipe out and save it I believe ours put the light out and all that I can't remember but it looks like this one you have here is even better than the one I have in 05 for 89 bucks you can't go wrong I don't have to have one here.
  5. Hayslayer
    Hayslayer Active Member
    539
    331
    The one you bought is a piece of xxxx. The pipe doesn't even match up to the diameter of the Prius pipe where it's supposed to splice into. You need to cut the OEM a few inches in front of the resonator. The replacement unit should slip snuggly over that cut pipe. The one you bought will be like a 55 gallon drum fitting over a fire hydrant. Learned my lesson on those. Had to take it and the rest of the exhaust to a muffler shop so they could use a hydraulic crimp machine to squeeze the end of the new cat pipe until it was the right diameter to fit. Spend the extra 20 bucks and get the right one.
    The pipe on the new one should neck down for the last 5-6 inches or so, like this one:
    Look up auction number 186197166961
    #5 Hayslayer, Apr 12, 2025
  6. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    So much crap out there, for a first timer these parts are just wrong. Take it to a shop or return them. Buy a Walker replacement, it will bolt in. Consider buying a new resonator too. Then the slip fit junction will be nice clean metal. The connection to the muffler is bolted with a sealing ring so no worries there. Exhaust work sucks, after doing a few hundred repairs I try to buy as many new pieces as possible to avoid slip fits of old into new. Broken bolts, old rubber hangers and working on my back just aren't fun anymore. I want to fix it once and be done.
  7. Tombukt2
    13,878
    2,521
    Durham NC
    Look man you can just drive the car with it not even connected you'll barely even know that it's not connected I drove around like this for I don't know about a week and an '05 with the same converter assembly or one almost exactly like it that's bigger than the original pipe comes that way for a reason but anyway yeah all that. No problem I mean what you were just going to put this all together if the pipe size was right and put a clamp on it and leave it well I don't ever do that I did that on a Cutlass w25 You know like 40 years ago big mistake leaks rattles nuts coming loose all that nonsense was just a crappy way to go but that's what we did back then hell that was before the exhaust shop and every place had a MIG welder but that's all changed and that's why I run it over there with the thing installed like I have it and if I'm not in any hurry I'd drive it around for a day or two it sounds kind of good I should just straight pipe it right out the back do the right things to the pipe to make it make the right noises and leave it But that'll be quite funny going down the road is the engine cuts off here and there You know all of a sudden you be whipping down the road with that nice exhaust sound and then all the sudden just quiet people be looking like what the hell. But your exhaust shop will quickly make a little piece that goes from the fat thing you bought to the skinnier thing in the car and then he'll swell the skinnier thing in the car a little bit so we can slip the pipe inside of or rather on the outside of the thing you bought That's how exhaust is supposed to go that takes him a whopping 19 minutes or something while you're talking and BSN around under the car.
  8. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    I will have to have my son take a better photo. At the moment it looks like where the two meet (new assembly and existing exhaust) it is pipe to pipe. One is about 2" and one just over 1.5". Does not look like a flange in the photo to me, but it's not the best shot.
  9. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    I got the link to the unit I bought from this site :( and bought it last year, so cannot return any more. But yes, you are correct that they do not match up size-wise and I would have been happy to buy the right one. I should track down where I got the link from a thread here and update it so no one else goes down this rotten path. I will provide some ebay feedback as well. My prius now sounds like a muscle car and the code is not gone yet. Need to address that joint.
  10. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Yep. At this point (335k) I am just trying to get rid of the code so I can sell the car and enjoy my new 2017 V in peace.
  11. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    My kid likes the sound. Me, not so much. :)
  12. Tombukt2
    13,878
    2,521
    Durham NC
    I meant just to get it over to the exhaust shop so they can squeeze and expand and make everything fit nice in about 18 minutes what they'll charge you for that I don't know usually it's not too bad but this day and age could be real ugly
  13. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Well, I tried to hire Midas when my son was out of town and they said they wouldn't work with a customer-supplied part... maybe they would do this part of it now that the part is in. And yeah, even an hour of work they said would be over $200.
  14. Tombukt2
    13,878
    2,521
    Durham NC
    No there should be a private place in your town I didn't look to see if you say where you are I usually don't anymore should be a private muffler shop I go there several and two or three towns near me and I just drive right down there I no one or two of the guys one or two of the places and boom that's it No franchise is not like Midas No absolutely not this would be like Chuck's muffler shop We do headers dual exhaust racing pipes replace catalytic converters on big V8 pigs You know whatever. Your little job you know being no problem.
  15. rogerthat
    rogerthat Active Member
    411
    129
    Georgia
    Hmm, can you post a photo of the actual unit you purchased? Maybe the auction has the incorrect pic as the description suggests a direct fit unit. There is no reference to an adapter. I purchased two of these in the past (Yitamotor brand)... one lasted almost two years and the other is working fine but it's only been a few months.
    Also, is your current cat the oem version? Don't let anyone swap that out as it's worth about $1k!
    Edit: After reading some of the reviews, it does appear that you will need an adapter. As Tombuk suggested, just take it to a local muffler shop, it'll take them 20 minutes to install that for you and it shouldn't cost more than $200 - just don't let them keep your original cat.
    #15 rogerthat, Apr 18, 2025
  16. MCCOHENS
    252
    101
    Chalfont, PA
    In this time of liability issues and such very few shops will work with owner supplied parts. You will spend a lot of time and if you find one the charge to make yours fit could be surprising. I would say, partially in humor, that driving to Durham NC and using Tom's guy might be easier. Or just put the current system on FB and buy the correct cat. A walker bolts onto the downpipe in front, and slides over the resonator pipe in the back. Just tight enough to make it a challenge but it will clamp tight without drama.
  17. Hayslayer
    539
    331
    or just buy another one for $125 that fits correctly out of the box......
