Exhaust Flange gasket
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Casey Cronkright, Oct 10, 2020.
  1. Casey Cronkright
    Casey Cronkright Junior Member
    Lansing,Mi
    Is it a good idea to replace the gasket when you do the spring bolts?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Yes but only if you don’t want an exhaust leak.
    Elektroingenieur likes this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    It’s not only a good idea, as @edthefox5 kindly mentions, but it’s also specified in the Repair Manual (more info), which shows the gaskets with the ● symbol, indicating “Non-reusable parts.”
    The gasket part numbers, per catalog Figure 17-02, Exhaust Pipe, are 17451-21060 for the connection to the exhaust manifold and 17451-23010 for the connection to the tailpipe assembly.
