Exhaust & Fuel
Discussion in 'Gen 2 Prius Fuel Economy' started by Abdulaziz_Barham, Mar 7, 2017.
  1. Abdulaziz_Barham
    Abdulaziz_Barham Junior Member
    68
    Jordan-Amman
    Three Touring
    Does bad Exhaust waste fuel ?? In prius 2008 ??
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    If you're redefining to a clogged catalytic converter, yes in most cases it does bring down engine efficiency.
  3. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
  4. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Well rust doesn't affect fuel economy if the exhaust system is still intact
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    AND.....a really LOT of stuff under the car is rusty if you look close enough.
    It's probably normal.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Hi OP I understand Prius is quite popular in Jordan.
    Where are you seeing rust? as my pipe is robust stainless steel. Maybe overseas has different construction.
    There is a rusty manifold that connects from the engine to the exhaust pipe.
    In a few rare U.S. cases (road salt in winter) the manifold has rusted thru.
  7. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    How did you know about prius in Jordan ??
    Anyway i got my car by auction from USA
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Your profile picture shows Amman-Jordan location, can you see it? We see it.
    Abdulaziz_Barham likes this.
  9. Sam Spade
    2,036
    1,024
    2017 Prius c
    THAT was not the question.
    The question was: How do you know that the Prius is popular there ?
  10. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I posted news story some time time ago, Jordan is like #3 Prius market to Japan and USA or something like that
  11. Mendel Leisk
    42,205
    If the muffler falling apart internally due to rust that'll impact fuel economy, due to what's called "back pressure"? Is the muffler stainless steel? Our 3rd gen is lasting pretty good, but I think it's starting to rust a bit; I'm not really sure.
  12. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    I got the carfox report and it show that (Salty water sinking ) then soled by auction in USA to Jordan maybe that what make it rusty fast ...
  13. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    I don't think so , because all the prius cars came from USA or Europe. To Jordan ...Not directly from Japan.
  14. Sam Spade
    2,036
    1,024
    2017 Prius c
    If that means it was submerged in salt water........
    You are just seeing the tip of the iceberg, so to speak.
    It is likely that EVERYTHING on the car will start to corrode fairly quickly, including the electronics, copper wires and electrical connectors.
    If you live near a large body of water where the humidity is high, this will happen even faster.
    Sad situation.
  15. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    Actually the was in Jordan Since 3 years till now . They refix it good . And replace all the damage parts
    The either in Jordan is very good no humidity and no water neer here eather.
  16. Sam Spade
    2,036
    1,024
    2017 Prius c
    You don't understand. The ONLY way to fix a car soaked in salt water is: Throw it out and replace the WHOLE car. It is impossible to "replace all the damaged parts" because that would be just about everything except the block and the frame.
    I am sorry that you are buying into this lie.....and hope that it really turns out OK for you. Being in a dry climate might save the day.
