Exhaust heat shield cover
Discussion in 'Gen 2 Prius Technical Discussion' started by Has Raf, Feb 14, 2025.
  1. Has Raf
    Has Raf Member
    180
    43
    Stoke-on-Trent, England
    Does anyone know how/where to reattach this? I can’t find any holes to re-fix it into place… It’s not rattling, just looks loose.
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    The condition of the stabilizer 48812-47020 is quite sad.
    Isn't it time to replace it?
  3. Has Raf
    Has Raf Member
    180
    43
    Yeah, probably. It’s going in for a service next week. Let’s see if they advise it. That wasn’t the subject of my post though….
  4. MAX2
    MAX2 Senior Member
    1,436
    490
    101
  5. Has Raf
    Has Raf Member
    180
    43
    Thanks for the part numbers. But, again as per my post subject, where does it attach? Also, I don’t think my shield looks much different to a new one…
  6. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    In the picture!
    Two mounting points on the top, two holes on the bottom, and SILENTBLOCK (black color), visible in the picture on the other bottom side.
    There should be places for mounting on the car body.
  7. Has Raf
    Has Raf Member
    180
    43
    It looks attached then. There are no bolts on the passenger side.
  8. Has Raf
    Has Raf Member
    180
    43
    Would this fit?
  9. Has Raf
    Has Raf Member
    180
    43
    Update: my heat shield was only being held on by 1 nut yesterday, so I ripped it off. I won’t be replacing it. It’s going straight in the bin! Could I get any money for it for scrap?
  10. Mendel Leisk
    42,369
    It was there for a reason.
  11. Has Raf
    Has Raf Member
    180
    43
    It was, but my question is, will it do any major harm without it? Most likely not.
  12. Mendel Leisk
    42,369
    Your call, google this:
    are exhaust heat shields necessary
  13. Has Raf
    Has Raf Member
    180
    43
    I’m asking the community…
  14. rjparker
    rjparker Tu Humilde Sirviente
    11,132
    6,982
    Texas Hill Country
    It keeps the floor of the hatch area from scorching or burning along with any adjacent hoses or wires. Toyota would not have spend money or add weight otherwise.
    However many choose not to replace it because of cost reasons and chance it.
    #14 rjparker, Mar 23, 2025
  15. Has Raf
    Has Raf Member
    180
    43
    Would the surrounding areas get hot enough to scorch and burn? It’s a 2007 Prius after all.
  16. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    When stopped at a traffic light, a significant portion of the heat from the exhaust pipe heated during the trip will rise up, heating the car body.
    Damage to the paintwork is possible, which will lead to corrosion and destruction.
    How likely is it? No one can say. The car is yours and the decision is yours.
    Has Raf likes this.
