Exhaust leak after engine installed
Discussion in 'Gen 3 Prius Technical Discussion' started by donzoh1, Apr 22, 2023.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    Can someone tell me which gasket I need between the exhaust manifold and catalytic converter in a 2013? It currently has a wire mesh gasket in there which I'm guessing has been compressed more than once and that's where I have a leak. Oreilly's sold me a Nickson 31387 steel ring gasket and I don't know if that will work.
  2. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    go here
    2013 Toyota Prius Parts like GASKET
    Enter your 2013 and Vin should op up. I have read that this gasket does need to be OEM. FYIW
    GASKET, EXHAUST PIPE, NO. 2
    Part Number: 17451F2010
    Supersession(s): 17451-F2010; 1745123042
    Exhaust Pipe Gasket
    Part Number: 17451-0D140
    Options: Right Front, Right Rear, Rear Front, Rear
    Other Names: Front Pipe Gasket, Exhaust Pipe Gasket, Converter & Pipe Gasket, Muffler & Pipe Seal, Cross Over Pipe Gasket, Muffler & Pipe Gasket,... More Names
    Replaces: 17451-28040, 17451-28060
    Description: Exhaust Pipe; Exhaust Pipe, Center; Exhaust Pipe, No. 2; Exhaust Pipe, No. 3. 2.7L. 3.5L, rear. Sedan, 2.0L. From 05/06. Japan built.... More Info
    Notes: Included with converter & pipe. Included with muffler and pipe. Part cannot be reused/reinstalled.
    MSRP $46.12
    $40.12 at OLATHE TOYOTA
  3. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    I've bought these many times and sometimes the $15 ones are equal or better quality than the $70 ones and sometimes the $70 ones are lower quality than the $15 ones. It's a mess. Your better off physically examining several options in person and picking the nicest one. Of course that's not easy these days when everything is online.
  4. donzoh1
    450
    153
    Lenexa, KS
    I wound up getting the OEM part at the dealership for $42. It does seem to be working which means it is a good part, I guess. I also saw one at a parts store that looked identical but had different packaging. It was $17 and it's the one I'll probably try next time. Not that I'm an expert on much around here but I'd bet OEM is not an actual requirement practically speaking for this part.
