Exhaust options for an 07 Prius?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bomber991, Jan 6, 2007.
  1. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(amishlandprius @ Jan 9 2007, 03:57 PM) [snapback]373253[/snapback]</div>
    That's a 'jake brake' and, no, I don't think the Prius uses exhaust backpressure to aid engine braking.
  2. ttaylor667
    ttaylor667 New Member
    <div class='quotetop'>QUOTE(cairo94507 @ Jan 9 2007, 04:01 PM) [snapback]373255[/snapback]</div>
    Just put it on cruise and snooze. Works well till you get to the first corner or first pedestrian.
  3. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    Re: baffle -- the one I was thinking of was one the intake side.
    I haven't pulled the cold air plumbing on my Prius, but on a bud's Corrolla there was this section of weirdly textured baffle stuff between the air inlet and the air filter box. Maybe the Prius doesn't have this, but if it does, removing that should help with making more noise. It's not exhause note, but it will sound different, and louder. What the car magazines call "intake thrash" or something. But it's a free mod, and your Prius will be slightly different from the others going down the highway. And you can tell people it adds 10HP and 2MPG.
    As to the exhaust system on a Prius, pretty conventional, cat, pipe, muffler, tailpipe. I was thinking a local muffler shop might be way cheaper than getting the bolt on stuff (Tom's is $700, Ganador nearly $600) for a tweak like this, but you never know. Just pointing out another option.
  4. John in LB
    John in LB Life is good
    399
    27
    Orange County
    Seriously, I do think there is an engineering problem with the Prius concept that should actually be remedied.
    As noted in other posts, people near the car may not notice it when the IC engine is not running (such as walking across a supermarket parking lot). I have noticed this first hand and I think it is a real danger for pedestrians getting hit by hybrid type cars.
    I believe the answer should be a small buzzer (or engine sounding hum) that would actually be activated whenever the car is in motion but the IC engine is off. Think of those annoying reverse beepers that some vehicles use as an example. To be clear, the unit should make a relatively quiet sound comparable to a car engine idling that is barely audible from inside the car (no VROOM VROOM sounds...)
    I actually think this should be mandated by the government, similarly to brake lights and other basic safety components.
    That's my 2 bits - now everyone can get back to insulting each other..... :p
  5. bomber991
    bomber991 New Member
    24
    <div class='quotetop'>QUOTE(John in LB @ Jan 15 2007, 12:55 PM) [snapback]375938[/snapback]</div>
    Yeah, I think that it will be mandated once these super quite cars become much more mainstream. I noticed that too while driving through parking lots with the Prius. People just plain don't hear it so they don't see it.
    So I guess they'll either make the car louder or make it do less damage to pedestrians if you hit them. Or, they should have had daytime running lamps on the Prius. I don't get why this car doesn't have those.
  6. John in LB
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(bomber991 @ Jan 15 2007, 01:54 PM) [snapback]376026[/snapback]</div>
    LESS DAMAGE to pedestrians??? The cars already use lots of plastic... and the tires: well, they are made of rubber... don't you think that's soft enough? Maybe that's why Toyota only recommends 33 PSI for tire pressure and not 40 PSI.... :D
    Better yet, we can put airbags all over the outside of the car !! :p
  7. koa
    koa Active Member
    980
    45
    Hawaii
  8. John in LB
    399
    27
    Orange County
  9. bomber991
    24
    <div class='quotetop'>QUOTE(John in LB @ Jan 16 2007, 04:35 AM) [snapback]376176[/snapback]</div>
    lol, well, when more than 1% of the population drives these quite cars, I think we're going to see pedestrian accidents go up significantly. I'm sure there will be a group like MADD, probably something like MASC. Mothers against silent cars? Anyways, the point is that they'd lobby for the cars to be designed to do less damage when hitting pedestrians, or have th government add that to their little safety tests as a requirement or something.
  10. bomber991
    24
    <div class='quotetop'>QUOTE(viking31 @ Jan 17 2007, 02:26 PM) [snapback]376987[/snapback]</div>
    lol, the idea is that the 4 cylinder fart cannon sounds better than the 4 cylinder silent muffler. Yeah, of course a 454 is going to sound way better.
  11. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    <div class='quotetop'>QUOTE(bomber991 @ Jan 17 2007, 02:40 AM) [snapback]377026[/snapback]</div>
    Well....opinions may vary on that point (assuming you consult people over 18 of course).
  12. bomber991
    24
    <div class='quotetop'>QUOTE(cairo94507 @ Jan 17 2007, 06:20 AM) [snapback]377110[/snapback]</div>
    Hi everyone. I'm 22 and I drive a subaru wrx. Don't get why you guys think I'm so young.
    Anyways, I was just saying you can hear the engine better with a more open exhaust, and from that I was saying that the sound of the engine is better than no sound.
  13. viking31
    viking31 Member
    515
    West Central Florida
    <div class='quotetop'>QUOTE(bomber991 @ Jan 6 2007, 06:19 PM) [snapback]371874[/snapback]</div>
    Nothing like the sound of a 4 cylinder engine at 4,500 RPM spitting through a 'Chock full o' Nuts' exhaust can. Just makes the hair on the back of my neck stand up!!
    M'mm boy, I'd trade that sound any day other than, say, some wimpy 454 sporting twin Holley's burning wide open with straight pipes.
    Let's see your dad is 55 and wants to put a fart can muffler on a Prius??? Someone help me here...
    Rick
    #4 2006
  14. viking31
    viking31 Member
    515
    <div class='quotetop'>QUOTE(bomber991 @ Jan 17 2007, 07:28 AM) [snapback]377112[/snapback]</div>
    I don't know, maybe I'm old school, but really the sound of a loud 4 cylinder is like fingernails on the chalkboard, it has a girlie or wimpy sound. I suppose it boils down to a matter of opinion, I really prefer 4 or 6 cylinder engines to be quiet.
    Rick
    #4 2006 quiet Prius
  15. bomber991
    24
    <div class='quotetop'>QUOTE(viking31 @ Jan 18 2007, 11:10 AM) [snapback]377226[/snapback]</div>
    Sounds more like a weed eater or a lawnmower to me. Which isn't exactly the most beautiful sound in the world unless you just love working in the yard.
  16. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(bomber991 @ Jan 17 2007, 04:28 AM) [snapback]377112[/snapback]</div>
    Well, that is the impression that is imparted from reading your posts.
  17. Pinto Girl
    3,093
    350
    There's nothing quite like a well driven car with a manual transmission to demonstrate the driver's skill...a well timed heel-and toe downshift, for example...
    This is something I love to hear!
    But a car with an automatic --- or worse, a PSD like the Prius --- is, I think, better seen and not heard. I mean, the engine doesn't make mechanical music like, say, a Porsche, the driver has no control over the RPM's, and the exhaust note of a smaller 4-banger isn't perhaps the prettiest sound out there...sounds like a good case for keeping the stock muffler.
    Also, regarding your age, 22 *is* young!!!
  18. slvr_phoenix
    slvr_phoenix Tinker Gnome
    84
    You see, there's this handy little device on the Prius called a brake... ;)
    You know, that almost explains why my tires were at 29PSI when I drove it home from the dealership. But this is the first I've ever heard of this. Is that true and is there an explanation why?
    Well mine already has foam pipe insulation in the grill that should help front impact. I suppose I could wrap my Prius in bubble wrap and duct tape while I'm at it. :lol: (Might as well add tin foil to protect from alien mind probes too.)
    Or there's Floam. Dang. Could you imagine a whole Prius covered in Floam? I'd love to see that in a Floam commercial. "Make your Prius safer with Floam."
  19. Duffer
    Duffer Member
    271
    Be a good son and tell your dad to save his money. The last thing that we need is another buzz bomb on the road! As he puts miles on his new car, the exhaust will get a little louder. The best bet is to start an exercise program, get out and start walking at least. If pops is falling asleep at 55, he may be dead by 65!
