Exhaust pipe hangs really low, think my rear bumper is lower than front
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by comatoes, Dec 31, 2015.
  1. comatoes
    comatoes #GreenLife
    288
    17
    My prius is a 2007 and has 140k. I think the lower end is lower than the front. I have about 4 inches of clearance from the horizontal exhaust to the ground.
    Can you tell from the picture?
    Nexus 6P ?
    #1 comatoes, Dec 31, 2015
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    You should check to make sure all your rubber hangers are still in place and not damaged.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    Looks perfectly normal just like my 07.
  4. Mendel Leisk
    38,895
    This bit looks fishy?
    Assuming you don't have a floor jack and safety stands, you could just put some 2x pieces up against that curb, and back the back end up onto it, have a better look.
    Patrick Wong likes this.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,240
    Orange County, CA
    Your exhaust should not be hanging that low. Most likely your hanging clips may have come off from hitting something.
  6. edthefox5
    10,096
    4,810
    Clearwater, Florida
    Sorry missed that exhaust part I was just looking at the stance which is fine. The exhaust has been damaged.
  7. Mendel Leisk
    38,895
    Looks like it's taking a right angle there, hanging down.
  8. Patrick Wong
    18,200
    6,479
    It is not obvious that the exhaust system has a problem. The point circled in the photo is where the exhaust pipe bends to the right prior to joining the muffler.
    As previously suggested the OP needs to get under the car to see whether there are any missing exhaust hangers. If there are no unusual noises and no hangers are missing then don't worry.
  9. Mindmanyplaces
    Mindmanyplaces New Member
    Idaho
    My 05 Prius also had the exhaust hanging low like yours. I took it to the local shop and they could not find a problem. I paid them 45$ to re-rout the pipe and fixed the problem. Gained 2 inch in clearance.
    comatoes likes this.
  10. comatoes
    comatoes #GreenLife
    288
    17
    That's awesome! Thanks for the tip. I may do this since I'm sick of my car scraping going up a steep driveway.
    I wonder if there is any negative to doing this? My car is way past warranty so that isn't an issue.
