Exhaust smell at First start of car in the morning during cold
Discussion in 'Prius v Technical Discussion' started by Ohid, Jan 17, 2022.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    My Prius Alpha 2015 has exhaust smell at the first start in the morning during cold. Here not very cold. Only 10-20°C. The smell last only 1-2 minutes and not found inside the car. Is it normal at the cold? What is your experience?
  2. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    Park the car facing the opposite direction if possible. See if there is still a smell...
    REVVL V+ 5G ?
  3. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Its engine normally start after moving from the garage. First few minutes it ran on battery. So this smell found outside of garage and mostly near the tail pipe.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,784
    2017 Prius c
    Then why do you care ?
    Yes, likely normal for the actual exhaust to look and smell slightly different when started cold.
    The fuel mixture will be slightly richer and the catalytic converter will be cold and not doing much.
    Air_Boss, Ohid and Mendel Leisk like this.
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Thanks.
