exhaust smell in cabin
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusmanneedhelp, May 21, 2022.
  1. priusmanneedhelp
    priusmanneedhelp Junior Member
    26
    Arizona
    Hello. Previous owners replaced the cat and welded it on poorly. Left an exhaust leak that I later fixed to pass emissions. The smell still remains in the cabin and I still have the p0420 code.
    Can a bad cat cause an exhaust smell to leak into cabin?
    Ive checked all up and down the exhaust system and I find no leaks. None at the manifold either.
    Is it time to bite the bullet and get a new cat?
    P.S I have also replaced the oxygen sensor just to be sure but the issue remains.
    thanks
  2. JC91006
    16,936
    8,647
    There should never be exhaust smell in the car, that's kinda dangerous. How did you pass emissions with p0420? That should give you a check engine light
  3. priusmanneedhelp
    26
    Arizona
    Sorry if I worded that weird but I'm trying to pass emissions right now. Def have a check engine light. Its a slight exhaust smell when Im driving. seems to go away when the heater is on. The smell lessened when I repaired the exhaust leak on the poor weld.
    Would a bad cat cause this smell in the cabin?
  4. JC91006
    16,936
    8,647
    A bad weld would only make the exhaust really loud, the gases should not get into the cabin.
  5. priusmanneedhelp
    26
    Arizona
    wasn't ever really loud. Wasn't a huge leak but was def leaking when I did the soapy water test. Fixed it with one of those jb weld exhaust tapes. What would cause exhaust smell in the cabin?
  6. JC91006
    16,936
    8,647
    I don't know how exhaust can get inside the car, maybe if the mixture was too rich. The oxygen sensor is oem right?? Denso? I've bought cheap aftermarket Catalytic converters, not all of them work. You'll still get a check engine light from the cheap replacements.
  7. priusmanneedhelp
    26
    Arizona
    yup oem denso.
  8. bisco
    52,862
    could it be in the engine bay, and coming in through hvac?
  9. pasadena_commut
    pasadena_commut Senior Member
    3,068
    953
    Southern California
    The previous owners replaced it because why? Stolen? Sometimes the thieves are not very bright and make cuts in the wrong places. Maybe not even all the way through a pipe, just through the wall. Treat it like any other exhaust leak problem. With the car up on jacks spray along the exhaust with soap water while a helper blows air into the tailpipe with a leaf blower, and like for bubbles.
    For whatever its worth, my son's POS RV had these issues and it was leaking at every junction where two pipes were joined with a gasket and some bolts. It was also leaking at the exhaust manifold due to multiple broken bolts there.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    You probably either have the wrong donut inthe header connection or you reused the oem donut and it’s damaged.
    Take it to a muffler shop.
    tangerino likes this.
