Exhaust with white smoke, looking for fire
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AmericanIdiot, Feb 18, 2025.
  1. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,515
    Durham NC
    No please don't put any of that in the Prius even some of this latest stuff in the blue bottle with green on the label and all that but they've come to my shop with that stuff. And well personally I don't have any part of it If you want to pour that in your stuff that's your business and you've got possible radiator clogging that stuff has to flow all through your cooling system all the pumps on our cars and all that business you're going to have the sealant crap floating around I don't think so on your stuff yet that's your business but over here no we're not going to be having any of that You just making a lot more nonsense for me to clean up and I'm charging you for it so you know let's not be doing that That's just for the let's see factor maybe possibly it might yeah forget all that You know might let you get the car into somebody else's hands real quick so it can fail tomorrow or the next day but you know I don't want to be dealing with any of that.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,054
    951
    Southern California
    I have VRP in my car now and it did not cause any sort of smoke. 139K miles (something like that, too lazy to walk out to the car to check.) I don't believe that anybody claims that it cleans the top of the piston. Oil isn't really supposed to be in there, and if it is it isn't going to have much time to work before it is incinerated.
    The tesslong front and side borescope for around $40 on Amazon gives very nice pictures. But you need a phone with a USB C connector, because it does not work well through a USB-C to USB-micro adapter. It looks forward or to the side, but not backwards.
    DO NOT USE A HEAD GASKET SEALER. Well, maybe OK if you intend to junk the car very soon because it is developing some other intractable problem. The sealers will gunk up everything in the cooling system, won't hold forever, and will eventually come back to bite you in the butt.
    Try testing the pressure in the cylinders. It is harder to screw up that connection, since it screws in. If you pressurize the one you think is a problem and the fluid rises or bubbles in the radiator neck, then there is definitely a path between the two. Probably a blown head gasket. Possibly something worse.
    Did the car ever overheat or get low on coolant or oil? Failed head gaskets are not very common in this vehicle. Unlike the 3rd generation, where they are a very common problem.
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    So you changed the oil and it started smoking? But that could be the reason.
  4. AmericanIdiot
    AmericanIdiot Junior Member
    46
    Isn't the claim of VR&P is that it will clean up the sludge of the oil control rings so that they move freely and scrape down the oil out of the cylinder? So if the oil control rings aren't functioning correctly, wouldn't there be oil in the combustion chamber (along with oil from the PCV)?
    So the head gasket sealer is really a last resort thing. If the car isn't worth fixing because of other issues, and I'm just going to roll the dice until it dies situation. It's definitely not my preferred solution, but if it doesn't make financial sense to repair the head gasket then spending $25 for something that might extend the life of the car a year isn't too bad.
    Compression test with looking at the radiator makes a lot of sense. I'll try that.
    The car has never overheated or run low on coolant or oil. I was also surprised about the potential of a failed head gasket, but there are a few other people on here who have asked about it. I am aware of the 3rd gen problems, so that's why I was alarmed when I saw the white smoke.
    Not that I know of. I noticed the smoke a few days ago. It could have been there for longer, but I didn't notice it. I don't think it's related to the oil change directly, but more that Valvoline Restore & Protect claims to remove carbon deposits and so that in combination with the blown head gasket could explain the clean spot on the #4 piston head. That is just a guess though.
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    What condition is the oil in now?
    Сolor?
    Viscosity?
    If the oil really started to wash out slag from the engine, then this slag will settle in the crankcase at the bottom of the cover.
    The oil pump, catching all the muck from the bottom, will quickly become clogged.
    Without lubrication, the engine will come to an end.
  6. AmericanIdiot
    46
    Oil condition looks normal -- specifically no milkshake. It's pretty clean on the dipstick and looks fresh. I'm guessing the gasket has only failed between the cylinder and the cooling system. No contamination of the oil system as far as I can tell. Obviously the situation can change if the gasket keeps deteriorating.
  7. AmericanIdiot
    46
    So I took it into an independent hybrid shop that mostly does Toyotas. I've used them before and trust them to do good work.
    They re-did the exhaust gas leak detection and it continued to be negative.
    They performed a leakdown test and the #2 and #4 cylinders were holding little pressure. The left dial was at 50psi and the right dial was at about 10psi for both cylinders. The best guess is that it's burning oil since the piston rings aren't doing their job. They said I could fix it or continue driving it with the concern of the burning oil will eventually foul the catalytic converter (original 2007).
    I have Hybrid Assistant and have it set to auto start whenever I'm in my car. I found out that it records every trip I've made and I was able to see the coolant temperature for many trips and my temps are always in the 180s
  8. pasadena_commut
    3,054
    951
    Southern California
    Is that not also consistent with a wide variety of valve problems? Possibly even timing belt/camshaft issues if they prevent both valves from being closed at the same time. I'm sure they put the piston at TDC, and equally sure they didn't scope inside to verify that the valves were actually in the correct positions. There are ways to tell where the air is going. For instance, listening to it. If the intake valve isn't closed when it should be, and a problem cylinder is kept pressurized, at least some of that air should come back out the throttle body. And so forth.
    Is the right dial really psi or is it % loss? Leaking 10% is normal. Leaking 40 psi to get to 10 psi would be terrible, that's an 80% loss. A car would run like crap with a compression issue like that, but that was not the case in the original post, just a little smoke.
    What did the dials read on 1 and 3?
  9. AmericanIdiot
    46
    I think you're right and I'll go back and ask them to perform it again. Here are the gauges from the videos they sent me in order from cylinder 1 through 4.
    [​IMG] [​IMG] [​IMG] [​IMG]
  10. pasadena_commut
    3,054
    951
    Southern California
    Maddox? That's a Harbor Freight tool.
    Cylinder Leak-Down Tester
    It is a little surprising to find it in use at an actual mechanic's shop.
  11. AmericanIdiot
    46
    Went back today and had them re-do the leak down test. The cylinders are holding compression just fine. The smoke is still a mystery, but I'm leaning more toward burning oil since that's the fluid that is disappearing. I'll review the prior responses for more ideas to pursue. Much calmer since it doesn't appear to be a blown head gasket.
    There was some drama in that I told them I wasn't confident that they had down the leak down correctly the last time I was there. We decided to do another one at half price. This time I watched the tech doing the leak down and had to correct some errors (setting the #1 piston to TDC, rotating the engine to get the next piston to compression TDC and not exhaust TDC). I had to explain to the owner that there are two TDCs and he thought I was a difficult customer and offered to refund my money. Luckily the tech had thought about what I explained (I'm guessing he was trained incorrectly) and was able to support my argument. The owner did the right thing by refunding my money since they had incorrectly performed the test and no charged today's test. I'm glad he took responsibility for their error. I'm not super happy about the situation -- I shouldn't be the one training their techs on how to perform diagnostic tests. When I initially went there, they were really small and the owner's brother was the one working on cars. Since I've come back, the shop is expanded and I don't see the brother around.
    Anyhow, I might have to find a different shop.
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,084
    6,947
    Texas Hill Country
    Your burning oil plain and simple. The rings wear out, a common gen2 problem. It needs a rebuild or you risking the very expensive cats. Your shop diagnosed it the first time.
    Sometimes logic is difficult and clues are scarce. Not in this case. No oil or additive will fix it.
  13. hurricos
    hurricos Junior Member
    74
    24
    Burlington, Vermont
    Good to know RE: seals -- I have oil consumption and occasional smoky starts, but no coolant loss. I might be lying to myself, but it's been like this for 13E3 miles, so :shrug:
    IDK about the "overwhelm" characterization -- cold catalytic converters don't do very much.
  14. pasadena_commut
    3,054
    951
    Southern California
    Perhaps the OP is overthinking this. If somebody tells you "my car smokes only on startup" it is almost invariably a problem with the valve seals leaking. I don't know if the Gen 2 Prius is one of those motors where it is relatively easy to replace these from the top, or if it requires the head to come off. I have seen references here and there on this site to bad valve seals, but not a procedure for replacing them.
    Hmm, on the other hand:
    Leaking valve seals often result in poor leak down tests. The OP is not seeing that, at least not yet. Or maybe the engine was too warm at the time of the test for the leak to appear?
    Some people claim that if the drain channels from the head are at all blocked that it can result in oil leakage through the valve seals. Not sure I believe that. Certainly not worth pulling the valve cover to find out. Maybe try Valvoline Restore and Protect on the next oil change. If there is gunk in those channels that will probably clean it out, and if there isn't, it won't hurt anything.
    #34 pasadena_commut, Feb 25, 2025
  15. rjparker
    11,084
    6,947
    Texas Hill Country
    Valve seals cause the cold start puff; rings cause the major oil consumption which is slower but continuous.
  16. AmericanIdiot
    46
    I ran a compression and scoped my cylinders this morning
    All the cylinders came out to around 125psi.
    Here are the photos of the tops of the cylinders and the valves in order from left to right.
  17. pasadena_commut
    3,054
    951
    Southern California
    Odd that in each there are two dark valves and two light ones. Is that normal for a Prius? Are the same ones dark in each cylinder (both intake or exhaust)? Looks like the larger valves are always darker, whichever one those are. I didn't see any drops of oil. Some parts are more reflective than others, but in borescope pictures that is often due to slight changes in the angle of the camera or light, rather than a little bit of oil.
    In a picture search found similar shading here:
    Rebuilt the Engine; Won't Go Now??? | PriusChat
    but that engine has bent valves. Here is another with the same shading pattern:
    I have never rebuilt an engine, naively would have expected all the valves to look the same from the inside of the cylinder.
  18. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Lean mixture, greater heating of the exhaust valve. Therefore it is light shade.
    #38 MAX2, Feb 27, 2025
  19. AmericanIdiot
    46
    There's also the matter of the PCV valve putting oil back into the intake manifold and having carbon build up on the intake valves. I imagine that's why the darker valves are probably intake valves. I don't know how that balances out with the cleaning effect of port injectors though (maybe only on the back side of the valves?)
  20. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    The exhaust valves are always hotter so any deposits will bake on. That's why they are different color. The intakes stay about the same temperature as the rest of the combustion chamber
    Leakdown tests will not find stuck oil control rings. The compression rings will seal just fine until they get carboned up & seize.
    The same is true for valve stem seals. Take the seals out and throw them away. The engine will run just fine, other than sucking down quarts of oil.
