Exhaust with white smoke, looking for fire
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AmericanIdiot, Feb 18, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    Does that heat translate into more failed stem seals on exhaust valves than on intake valves?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    I generally don't see many valve problems. Not like I did 20-30 years ago. There is probably some wear in the valve guides, but oil rings will go first. By the time that happens, the car is old enough that engine replacement is economically questionable.
    Occasionally a valve spring breaks and drops the valve- which destroys everything.
    The materials they use for seals are much better. I seldom see oil smoke on start up or decel - those "classic" symptoms of oil past the valves.
