exLEDusa 10pc LED set
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Steve Type-4, May 23, 2012.
  1. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
  2. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    Liking it! But it seems it is non-sunroof only?
  3. pghjerry
    pghjerry '24 Prius Limited
    58
    Las Vegas, NV, USA
    2024 Prius
    Just ordered a set for mine! Cant wait!
  4. Steve Type-4
    Steve Type-4 Trading HP for MPG
    174
    102
    SoCal
    REVIEW:
    I owned a set of interior LED light upgrades for my previous Acura RSX. Being absolutely satisfied with the output of these LED lights, I decided that the interior lights were the first thing to upgrade in my new Prius. The LED performed as expected.
    For the Prius, I opted for the 5000k output instead of the 6000k output I had for the RSX. The difference is noticeable. Here, we have a pure white light output vs. the 6000k upgrades which outputs a bright white light with a noticeable bluish tint. For comparison, here is a shot of my 6000K exLEDusa LED upgrade for the RSX:
    The entire set consists of 10 pieces:
    • 2 overhead map light replacement LEDs
    • 2 front door courtesy light replacement LEDs
    • 2 rear license plate LEDs
    • 2 vanity mirror LED
    • 1 cabin dome LED
    • 1 rear cargo LED
    Just like the LED upgrade for the RSX, there is a tiny Philips screw that you can turn to adjust the brightness. The level of brightness is from "off" to blindingly bright (you'll see):
    To make installation even easier than they already are, each of the LED board have the designated lighting area printed on them, for example, "Room Lamp Module" is imprinted on the pair of overhead dome map LED boards.
    Here's an overview of the stock vs. the LED upgrade by exLEDusa:
    Cargo area with stock lighting.
    Cargo area lighting with LED upgrade by exLEDusa.
    Front overhead map lights on with stock bulbs.
    Upgraded front overhead map lights with LEDs by exLEDusa.
    exLEDusa passenger side vanity light upgrade.
    Door opened.
    Another view of the interior cabin.
    From afar.
    Close-up of cabin.
    The upgrade kit costs $99.99 shipped. If you have a few extra cash to spend and would like a brighter, energy efficient interior lighting, this upgrade is definitely worth the commanding price. To get your hands on your own set, order it directly by clicking on the following link:
    exLED Toyota Prius ('10~) (Map, Dome, Vanity, Trunk, Door, License Plate) custom interior light kit
    Derek77, pghjerry, 32kcolors and 2 others like this.
  5. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
  6. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    That's a great kit with great results. A bit pricey but not many kits allow you adjust the output to your liking. Unfortunately, the kit is not available for the solar roof package either (which is common with most LED kits).
  7. WE0H
    WE0H Senior Member
    3,247
    528
    Time to lay out a board for the solar roofed car's :eyebrows: Does anyone know the part number of the LED's on the boards that company sells? Either that or a reliable seller of the LED's with trusted advertised color temp numbers? I certainly can layout a board in ExpressPCB and post it so anyone could copy it.
    Mike
  8. Steve Type-4
    174
    102
    SoCal
    That sounds like a swell idea. Lemme see if the p/n are visible in the board.
  9. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Those with SR can still get the kit plus a couple of 360-deg multi-SMD 194/168 type LED bulbs in the same color temp from the same manufacturer for $10 or so to put in the front dome. Unless you want go the trouble of fabricating a board for it.
  10. HI MPG
    789
    133
    93
    Orange County, CA
    Very true. Or you could even get one of the 6 SMD panel (like the the one for the dome) and mount with double sided tape. I'm currently using that set-up with the iJDM units. As bright as the OP's interior but with a very slight bluish tint.
  11. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Which is a better match for the turn signal mirror puddle lights.
    If you plan to upgrade to the turn signal mirrors someday, be sure to select the 6000K color temp or you might get annoyed at the color mismatch once you have the mirrors installed and shell out another $99.
  12. WE0H
    WE0H Senior Member
    3,247
    528
    That sounds like an easier solution. I'd still like to know the part number of those LED's or a supplier for my own experiments ;)
    Mike
  13. d2mini
    d2mini Active Member
    519
    106
    Houston
    Wait, first you say the slightly bluer tint is better match for the turn signal lights and then you say the 6000k is a better match?
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    6000K *is* the slightly bluer tint. 5000K is white like shown in the OP.
  15. d2mini
    519
    106
    Houston
    :rolleyes: :doh: :redface:
    I'm going to bed now. :bolt:
  16. Steve Type-4
    174
    102
    SoCal
    This is how the overhead maplight LEDs sit flush in its housing.
    Shot of the LED on. Hard to shoot with just my iPhone lol.
    EDIT: Yay Tapatalk!
  17. dbastille
    dbastille Junior Member
    23
    New England
    Just got mine in and installed.....great but....My map lights don't fit!
    I have a 2011 level 4 and they are way too big to fit.
    Ended up using the license plate lights for them. Only 2 LEDs each but better than looking at those yellow oems.
    Anyone else with this problem?
  18. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    I have swapped out all of the interior bulbs (except the vanity bulbs, but that will happen soon) with LEDs from iJDMtoy.com (#2825 5-SMD and 12-SMD)and Autolumination.com (#194 T10 wedge for license plate, #5050 SMT festoon) . I also swapped out the front parking lights and license plate bulbs. No real problems with the installation except the festoons are a little big, but still manage to stay in the clips. I have ordered a set of LEDs that contain resistors that are supposed to work as flashers, and will install them as soon as they arrive. If they work then I will post pics.
  19. khoakhoa
    khoakhoa Junior Member
    96
    28
    san diego
    I got the 5k set, definitely like it, big difference much nicer color and brightness then oem. Only problem is the 2012 Prius plug in has different map lights so I am in middle of modding the lights to work, hopefully...chop chop Lol.
  20. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Spent $22 for the interior LED's and license plate bulbs from DDM. Went down and they even put them in for me...the whiter light is so much nicer than the stock yellow tint stuff, especially in the cargo area.
    mgb4tim likes this.
