exLEDusa 10pc LED set
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Steve Type-4, May 23, 2012.
  1. kmkremer
    kmkremer Member
    227
    30
    San Diego
    This sounds good. I'm in San Diego as well. Where is DDM?
  2. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    They're open M-F 9-5.
    7171 Ronson Road
    Suite A
    San Diego, CA 92111
    or
    2317 Cherimoya Drive
    Suite A
    Vista, CA 92084
  3. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Thanks! Did you replace all of the interior lights (i.e. map lights, doors, footwells, rear overhead and cargo area) or only certain ones? Do the replacement bulbs have a blue or whit light? Any issue with them being too bright? Thanks for the help.
  4. priusG
    priusG Junior Member
    30
    Los Angeles
    FYI
    If you use the exLEDusa's, you can control the brightness.
    And they also have 5000K pure white (not bluish white)
    exLED Toyota Prius (for sunroof model) ('10~) (Map, Dome, Vanity, Trunk, Door, License Plate) custom interior light kit
  5. sdtundra
    1,314
    193
    Sacramento, CA
    I chose white, but you can get anywhere from green, red, purple, blue and different wattage for brightness. Mine are brighter than the stock ones but its a nicer white light thats not as harsh on the eyes.
    Tombiology70 likes this.
  6. Chunker
    Chunker My name is Chunker...I wear a hat
    71
    I originally got the LED light set from precision LED and wasn't satisfied with the light output. I replaced them with the exLED ones and they are WAY better...except maybe the license plate lights cause for some reason the exLED lights only have two LED's facing forward instead of down but no big since it's just the license plate light...=)
    priusG likes this.
  7. priusG
    30
    Los Angeles
    The BEST interior kit ever! :)
  8. Gonzo3625
    Gonzo3625 New Member
    Just thought I'd throw my 2 cents in, just got my exLED kit in the mail and got it put in today and it is amazing! Super easy to install and the sizes were perfect. The light adjustment is just great too!
  9. Air_Boss
    Air_Boss Senior Member
    4,208
    1,186
    New Yawk
  10. priusG
    30
    Los Angeles
    their homapage says they are on a blackfriday promotion now. 20% off
    exledusa.com
  11. Air_Boss
    4,208
    1,186
    New Yawk
    Coupon code not working...
  12. priusG
    30
    Los Angeles
    did you try
    BLACKFRIDAY
    for coupon code?
  13. Air_Boss
    4,208
    1,186
    New Yawk
    Yes, and it's now working.
  14. mr estrada
    mr estrada Junior Member
    43
    Nice. I'm in San Diego too! New owner of a prius 13 two and wanting to get my interior lights switched out for the LED set.
  15. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    Any tips on how to pull out the OEM light covers without breaking anything?
    I did the cargo light no problem. Lights behind visor won't come out.
  16. priusG
    30
    Los Angeles
    it is similar to this
  17. NaptownPrius
    271
    Napolis, Merlin
    I can't get the plastic cover to stay on now. Came out okay but had to remove that cover to lay LED panel inside.
    Sigh...
  18. scgator
    scgator Junior Member
    Gainesville, FL
    Just a heads up, the kit is on sale again for 20% off from exLEDusa for black friday. Code is BLACKFRIDAY13 and it is valid from today until 12/1
    priusG and WE0H like this.
