Expected mpg with bad hybrid battery
Discussion in 'Gen 2 Prius Fuel Economy' started by pkhoury, Apr 5, 2011.
  1. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Yes, running the A/C increases the current draw to several amps from the traction battery. Suppose you see a 5 amp draw and you are initially at 60% SoC with the car in Ready but stuck in a traffic jam. ICE will kick on at about 45% SoC. That's 15% SoC * 6.5 amp-hour of battery capacity, let's round that up to 1 amp-hour of available battery capacity before ICE-on. 1 amp-hour is 60 amp-minutes. Divide by 5 amps, leaves you 12 minutes.
  2. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    If you should happen to recondition the good modules, please post the resulting amp-hour capacity. The most worn battery I've looked at had 155,000 miles, but I was still able to get the modules up to 5.5-5.6 amp-hours capacity after three cycles. That's about 1% of actual capacity loss for every 10,000 miles. It would be nice to have more data points.
  3. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    One of the disadvantages of the Prius' hybrid design compared to Honda's IMA mild hybrid implementation which can run even with a dead traction battery.
  4. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    This is a good thing since the IMA batteries tend to last only 50,000 - 100,000 miles. But don't forget that there is no alternator, so something has to be done to keep the 12V charged.
  5. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    IMA isn't a mild hybrid system.
  6. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    I don't see any reason why the generator/converter can't charge the 12V even when the traction battery is dead.
    The generator/converter replaces the alternator in the IMA.
  7. fuzzy1
    10,687
    IMA has a backup 12V starter. HSD does not. Even if it did, I don't believe the eCVT can be run properly without the traction battery, so the HSD vehicle would still be immobile.
  8. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    The IMA battery powers the DC-DC converter. If the IMA battery is dead, then the DC-DC converter will not charge the 12V battery.
  9. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    For instance, if the smaller motor/generator doesn't have at least some current in it providing a holding torque, then that motor will just spin when the engine does and the wheels will not get any torque at all.
  10. pkhoury
    pkhoury Proud TDI owner
    183
    Texas Hill Country
    So in theory, if the Prius were able to operate with a dead HV battery, would it still be getting over 35mpg? Since these were rated at 60mpg originally, I'm thinking the gasoline engine operating alone should yield about 40-45mpg.
  11. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Go for a long highway drive at speeds always in excess of 52mph. That is the mpg you would get without the HV pack.
  12. pkhoury
    183
    Texas Hill Country
    Yeah, about the same as my TDI. My friend is hassling with the dealer over a battery replacement, but the dealer claims they're low on stock. Probably a load of BS.
