Expensive Oil Change & Tire Rotation?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PriusPeep, Oct 25, 2020.
  1. Prodigyplace
    12,716
    11,848
    Central Virginia
    i buy toyota filters by the case and Mobil One oil from Walmart. I then di my own oil changes.
    Tande likes this.
  2. Mendel Leisk
    42,355
    Could be. My last purchase was from dealership in September of 2016, was $9.14 (CDN), per liter, and yeah, 4 required.
    BTW, according to Toyota, it doesn't "keep" well, best to just recycle what's not used.
    Yup: LA dealership currently asking $12.45 USD, per quart:
    World Standard Automatic Transmission Fluid
    BiomedO1 likes this.
  3. Mendel Leisk
    42,355
    @BiomedO1 : checked with our nearby dealership this morning, Toyota ATF WS fluid is currently $11.98 CDN ($8.54 USD), per liter. Plenty in stock. :)
  4. BiomedO1
    BiomedO1 Senior Member
    4,625
    2,425
    Left Coast
    I'm sure if you shop around; anyone can find it cheaper. An automotive repair shop isn't going to do that. They're going to order from their tired and true parts distributor, which means retail pricing for the customer and they buy it for wholesale. They're not going to tell a customer they're holding the car - waiting for a parts sale.
    I'd occasionally get that same push-back from customers, when I use to run my dad's shop. I'd tell them that the parts I use; allows us to warranty the work we do. If one of our parts fail; we eat the cost. If you bring in cheap counterfeit parts that fail - you need to go back to the parts distributor to make it right and pay me again to do the job again. It's a lot cheaper than labor cost; because you've just shifted the burden of responsibility onto your self. That's the power of wrenching on your own car - you get to save money; but you also need to deal with counterfeit products if you go too cheap........
    Amazon is currently showing that 4 quarts is between $56.50 - $73 without taxes and shipping; depending on membership.
    #44 BiomedO1, Nov 10, 2025
  5. Mendel Leisk
    42,355
    Well, I can DIY change for about $38 USD (with the two washers), buying parts retail from dealership. If their service department was doing it, $100 USD would make them a bit of profit, considering it's about 1/2 hour labour.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,118
    6,975
    Texas Hill Country
    On this forum do it yourself is always the recommendation even when it's clear someone prefers to have the work done at a shop but is looking for a way to get a fair price.
    There are some methods to get a fair price as described occasionally in this thread even at dealers.
    More expensive repairs are best done at independents. To know who is good you should use them for the routine fluid changes. The best independents are small and never a chain; let them get to know you and they may prioritize you when the big job is needed.
    ColoradoBoo likes this.
  7. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    If you live in an area like I do the independent mechanics are completely (and I mean completely) ignorant about hybrids. I’m getting to the point where I won’t be physically able to do my own service so I tried reaching out to several of them in the area to simply change the oil and do a thorough inspection (which meant dropping the pans). Some of them flat out said they don’t touch hybrids at all and the rest looked at the list and said “I don’t do anything remotely connected to the hybrid battery” when they saw the part about checking the hybrid battery filter. One told be that the transmission fluid needs to be changed every 30,000 miles because it was a CVT!
    My choice of independents are over two hours away (the two nearest to me) who have any knowledge about hybrids ( The Car Care Nut being one of them).
    So I’m pretty much stuck with the local Toyota dealership.
  8. BiomedO1
    4,625
    2,425
    Left Coast
    I believe the gen1 Honda CVTs recommended that and current Subaru CVT recommends 25K miles changes under severe conditions (ie. towing or exiting the pavement). Who would've thunk that??? Sounds like that mechanic was just misinformed.
    IMHO; if you can find a honest mechanic that charges less than $100/hr - Print out the OEM page of what you want them to do, then double check their work. That and asking friends and family is kinda the only way to find one. If the person that recommends a good mechanic, doesn't know anything about cars - that's why you check their work afterwards. The guy might just be a silver-tongued devil.
    FWIW: $100/hr is big city labor pricing - Dealerships are around $125+ per hour.
    YMMV
  9. Classic Car Guy
    Classic Car Guy Active Member
    504
    136
    Northwest, USA
    What oil do you guys use on a 2018 with 18k miles living in Pacific NorthWest area which is 32-52 deg on winter raining all the time?
    Thank you in advance.
  10. ColoradoBoo
    ColoradoBoo Senior Member
    1,354
    982
    Monument, Colorado USA
    Whatever is on the oil fill cap...should be 0W-20. (Prius changed to 0W-16 but I don't know what year...my 2021 takes 0W-16 but my 2017 takes 0W-20.)
    Classic Car Guy and Prodigyplace like this.
  11. Classic Car Guy
    504
    136
    Northwest, USA
    I'll be working on the 2018 this afternoon. If I even find out that this car has a spin on oil filter,is it okay to use the Fram PH4967?
    The car is a 2018 prius the base model. (not prius C)
    Thank you for the follow-up.
  12. BiomedO1
    4,625
    2,425
    Left Coast
    DO NOT use the bottom of the line Fram, you need to use the Ultra or better filter. The bottom of the line filter is 5K mile and conventional oil (orange box). The Ultra will do 10K+ miles and specifically used with synthetic oils. READ THE FILTER PACKAGING.
    YMMV
  13. Classic Car Guy
    504
    136
    Northwest, USA
    I'm doing 5k oil change all the time with my 2007. And Iwill price the same on the 2018. Do I still need to swap with a better filter?
  14. BiomedO1
    4,625
    2,425
    Left Coast
    Not really; it's you car and your consequences. Your already ahead of the game since some people just don't do maintenance and just buy another car, sorry - roll-over financing, every 2-4 years.
    The alternative is to go with OEM filters. You can get them as cheap or cheaper online. I've found my dealership's online portal, that will match any advertised OEM parts price. I do a pick-up/will-call to ensure I get whatever the dealership is using on their customers cars. The last batch of oil filters I got was <$5 each and the parts counter guy gave me free replacement drain plug washers for each filter.
    I just prefer a bit more protection; since everyone is cost cutting. I don't want to be the person that ends up with the filter that marginally passed specifications. That's the same reason I pay the extra dollar for the 20K mile oil formulation. I'll never keep oil in there for that long, but I prefer the additional additive package - in case someone didn't get their morning coffee and let a few jugs slip by without enough additives.
    That's just me.....
    Classic Car Guy likes this.
  15. Classic Car Guy
    504
    136
    Northwest, USA
    ___________________________
    Youre absolutely right. I have a bunch of new toyota filters from my 2007. I haven't worked on this 2018 yet for its my wifes car and she always had it done on the dealer. This will be the first time for me to look on this car. I just bought the filter up ahead without even seeing the car closely. If its the same, I'll just install the fram on the 2007. I change the oil filter on that one every 4,000 miles since its over 175k miles now.
  16. Mendel Leisk
    42,355
    Pretty sure the 4th gen Toyota spin-on, and 3rd gen where owners have done the conversion (myself included) and 2nd gen, is:
    90915-YZZN1
    There is a longer filter that fits too, but not sure of the point. FWIW, just show up at a Toyota dealership parts department and tell them you need oil filter for a 2nd gen?
    BiomedO1 and Classic Car Guy like this.
  17. Prodigyplace
    12,716
    11,848
    Central Virginia
    My 2017 was not spin on. It was the cartridge like the older generations.
  18. Classic Car Guy
    504
    136
    Northwest, USA
    if in case its not a spin on. Along the future is there a bulletin that I can change this to a spin on?
    Wow I thought I was done with my old car conversion....
  19. BiomedO1
    4,625
    2,425
    Left Coast
    The longer filter is for the 3.0L V6 Toyota motors and it offers larger filtering area. I would probably use it, if I was running Valvoline protect & restore on the car or if your doing extended oil change intervals - beyond OEM recommendations. You really don't want that oil bypass valve to open up and dump all that sludge back into your engine.
    I was concerned with that small filter myself, when I first saw it on my 2012 Prius C. Hey; it works - the proof is all those Toyota's still on the road today.
    YMMV
    @Classic Car Guy; check Mendel's signature links. He has that outlined.....
  20. ColoradoBoo
    1,354
    982
    I don't know when the Gen 4 Prius switched from the canister to the spin on oil filter (good ole YZZN1 which is what our old 2008 Corolla uses). My wife's 2017 had the canister (which I hated) and my 2021 has the spin-on so I bought the replacement Toyota parts on the Amayama website and I think they ended up costing only about $60. I did have to wait for them to come in....took about 3 weeks or so (came from the Middle East). Search on this website, the part numbers you need are listed. (I look up there with every oil change and never had a leak, I was worried about that.)
    Prodigyplace and Classic Car Guy like this.
