Expensive Oil Change & Tire Rotation?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PriusPeep, Oct 25, 2020.
  1. Mendel Leisk
    42,355
    Yeah the return to spin-on happened a year or two into 4th gen.
    Gen 2’s are all spin-on.
    there’s a link in my signature* with info. Note, there were/are multiple versions of the main spin-on component, AFAIK they all work fine, mostly bored engineers with time on their hands.
    the one I got from Amayama was an earlier version, works.
    * on a phone turn it landscape to see signatures.
    #61 Mendel Leisk, Jan 3, 2026
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,118
    6,975
    Texas Hill Country
    Extremely unlikely. I would try the version sold for a gen4 nearest your year.
    Prodigyplace likes this.
  3. Mendel Leisk
    42,355
    #63 Mendel Leisk, Jan 3, 2026
  4. rjparker
    11,118
    6,975
    Texas Hill Country
    You have a gen3. Gen4 has block and many other changes which could make revisions relevant.
    Mendel Leisk and Prodigyplace like this.
  5. Classic Car Guy
    Classic Car Guy Active Member
    504
    136
    Northwest, USA
    Okay man this is what I got on the 2018 Prius Base Model. Thank god its a spin on.
    0-20W 5 Quarts Synthetic Oil
    90915-YZZN1 (Original 2018 Toyota Oil Filter)
    This is what I have in my stash and a lot. Do you guys think these would work a slong as it fits on the threading and housing?
    90915-YZZF2 (Original 2007 Toyota Oil Filter)
    PH4967 (Fram Oil Filter)
    Thanks!
  6. Classic Car Guy
    504
    136
    Northwest, USA
    It fits! So far I've done the oil and filter.
    I have to go to the mailroom first before I go to the rest of the mild service. Theres alot of things I found out that the dealer didn't do right. Hopefully when I open the air cleaner its not gonna be like the first time it seen daylight after its original assembly. s0092.gif
    Thanks!
  7. Classic Car Guy
    504
    136
    Northwest, USA
    Does the 2018 prius base model have service reminder and service mile tracker on screen?
    Just wondering because the 2007 I use has all of those.
    Thanks
  8. BiomedO1
    BiomedO1 Senior Member
    4,627
    2,425
    Left Coast
    Yes, maintenance minder will go off around 4.5K from last rest. It'll disappear when you get moving. If you ignore it past 5K, It'll stay on-screen until you manually clear acknowledge it.
    Classic Car Guy likes this.
  9. Classic Car Guy
    504
    136
    Northwest, USA
    Thank you for the follow-up and the help. Great to know you guys are here. I feel alot better now.
  10. Classic Car Guy
    504
    136
    Northwest, USA
    All set on the 2018 car. My wife is hardly using that car with still under 20k miles. Were always driving the 2007 and that's the one that I worked on a lot. Since the '07 has 177,000 miles, I started using 5w-40 oil (from the previous 5w-30). Surprisingly the car runs smoother with this oil, been quiet even in morning first start, lesser oil lost and able to maintain a better MPG in the stop and go driving. I notice that I go to the gas station lesser. I'm not sure if this is just a coincidence and I just rebuilt the hybrid battery. But also I been driving this car since I bought it back in 2018 as a used car with 98k miles. I use to change my oil previously set on 4,500 miles. Let's see what it looks like when it gets there. Anyone religiously using the same 5W-40?
  11. BiomedO1
    4,627
    2,425
    Left Coast
    I believe the 2018 calls for 0w20; IMHO - moving to 5W40 is a bridge too far to cross. Your way out of specs for a car engineered for 0W20. If you live where the snow don't stick, you might be able to get away with it. Your 2007 was engineered for 5W30; so pushing it to 5W40 isn't much of a stretch. When that 2018 engines stops and then restarts; it'll need to push 40 weight oil all the way up to the valve train. That's going to be a dry start every-time that happens.Thin oil has been proven on the race track; though they rebuild the motors after every race.
    If your getting oil consumption issues in the 2018, try moving to 5W20; but I wouldn't jump to 5W40.
    It's your car, do whatever you want.....
  12. Mendel Leisk
    42,355
    Excerpts from Toyota Australia Owner's manual:
    Full page:
    Excerpt:
    #72 Mendel Leisk, Aug 12, 2026 at 11:18 AM
  13. Classic Car Guy
    504
    136
    Northwest, USA
    LoL......
    read it again....:ROFLMAO:
  14. Prodigyplace
    12,716
    11,848
    Central Virginia
    But he is doing it on a 2007 BOUGHT in 2018. Different generation of Prius.
  15. BiomedO1
    4,627
    2,425
    Left Coast
    Reads like two different cars to me; but then again English is my second language. I tend to take things plainly; I expect periods and new paragraphs when changing subject matter.:rolleyes::censored: I can usually figure out technical service manuals and find a lot of mistakes in those too; but at least I can look at the unit and definitively say the manual is wrong. That's why I hate e-manuals; can't put corrections/notes in the margins so someone else doesn't make the same mistake. I usually print them and make corrections, but coworkers really PO me when they take my copy - don't ask or leave a note.:mad:
    YMMV
    #75 BiomedO1, Aug 13, 2026 at 9:58 PM
