Explain to me 'B' on the shifter
Discussion in 'Gen 2 Prius Main Forum' started by trungdok, Sep 25, 2015.
  1. trungdok
    trungdok Junior Member
    45
    Boston, MA
    I is really "simulated engine braking"? Or is it more of "turning off the simulated engine rolling forward"?
    In a regular car, the car rolls forward while in gear. For the Prius, when going downhill or sitting at traffic, only the electronic engine is used. So, I think this rolling forward motion is simulated with the electronic engine since it's not "in gear" at this point. I would assume the "B" option turns off this simulated "in gear" rather than simulate an engine braking. Seems to make more sense to me that way.
  2. Joerg1530
    Joerg1530 New Member
    Germany
    It's really engine braking. Btw, do the brake lights turn on when I use it? Do they if cruise control reduces speed?
    Jörg
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The brake lights only come on when you press the brake pedal. They do not come on with engine braking or cruise control. So you need to be aware of this if you have someone behind you.
  4. Joerg1530
    Germany
    That's what I thought, good to know for sure. Thanks.
    Jörg
  5. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    It is simulated engine braking.
    In very slow speed Prius mimics traditional automatic transmission car by using electric motor (or in some case even engine) to give small force forward. In very small speed switching to B doesn’t do anything.
    In higher speeds Prius mimics traditional automatic transmission car by using electric motor to slow itself a bit and charge battery slowly. If you use brake pedal it charges battery faster but if battery is already full it will just use normal brakes.
    If you’re in B-mode in higher speeds Prius mimics traditional automatic transmission car in low gear by using electric motor to slow itself a bit faster and charge battery a bit faster. If battery is already becoming too full it will just waste extra energy by spinning the engine (this is engine breaking). If you use brake pedal it charges battery faster but if battery is already becoming too full extra energy is just spend by spinning the engine faster (this is engine breaking that you can control).
    So only time you should use B-mode is when other vice battery would just get full charge and you would be using actual brakes. Using B in that situation will reduce wear on the battery (it won’t be charged as fast) and brakes (they’re used less).
  6. Mendel Leisk
    38,733
    The main, really the only, practical use for B mode: you have a looong downhill stretch ahead of you, so long that the battery will quickly come to full charge, and you will still have a long ways to go before reaching the bottom. In this situation using B mode will slow the rate at which the battery charges, delays the car having to resort to the regular brakes, possibly to the point that they will overheat, warp rotors, fade, whatever.
    jdcollins5 likes this.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I agree. And...
    I agree.
    Have read posts where people use "B" like downshifting with a manual. Slowing to a stop and other "tricks" inwhich they think "B" is beneficial.
    I don't recommend any of these other uses for "B".
    After so many years in Prius Chat I'm convinced:
    A: Many Toyota Salesmen don't even know what "B" is or does...source of great misinformation.
    And
    B: Toyota needs to provide a much more comprehensive explanation of how to use it, and what it does. Because the "What is "B"? " question seems to be a very common one.
    PLSPUSH likes this.
  8. bisco
    49,504
    is it explained in the o/m?
  9. Mendel Leisk
    38,733
    Very tersely. This is all she wrote:
    Isn't B a bit different on the plug-in?
  10. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    so....what is b?
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    B under the D in the Drive gears? | PriusChat was my try at explaining B, since then I am persuaded that B more aggressively uses engine braking than when the battery 'fills up'. So use B from the top of long down hills!
  12. bisco
    49,504
    that's poor, no wonder the confusion. i mean, it says it all, but that's not enough for some people. b on the pip is the same, but some people use it to trick the system i think.
  13. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    PLSPUSH likes this.
  14. PLSPUSH
    359
    132
    Tulsa, Okla.
    what's it for?
    never mind I have a c!
  15. Mendel Leisk
    38,733
    Still got B mode methinks. Use it on extremely long down hill runs, to avoid brake overheating, when battery has topped up. Say for example: coming down a ski hill.
    PLSPUSH likes this.
  16. bisco
    49,504
    press 'b' for bisco.;)
  17. PLSPUSH
    359
    132
    Tulsa, Okla.
    b for bob....just havin' some fun! although in the mostly flat state of Oklahoma I shouldn't need it
    not making fun of the question though.....I really never understood the "B" button either!
  18. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    B is for engine Braking, some engineer at Toyota was too honest to call it L, but you use it when you would use L in an automatic. (almost never).
    Sadly some uninformed car magazine writer made up that B stood for Battery, when in fact it charges the battery LESS than D does.
    PLSPUSH likes this.
