Extended lug nuts
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Chalicekey, Apr 19, 2019.
  1. Chalicekey
    Chalicekey Junior Member
    24
    25
    North Carolina
    Just got my 2010 Prius last week.
    Planning on JDM Style mods for visual upgrades.
    I thought about doing a wheel upgrade but don't want to sacrifice the miles per gallon.
    My idea to make the factory wheels stand out was to get some extended lug nuts.
    My question is for the factory wheels do I need the acorn style lug nuts or the flat?
    Thank you
  2. Mendel Leisk
    42,352
    This link is some replacement lug nuts I purchased. The seat is conical, but that's basically just for the temp spare. With the regular alloys, it's the captured washer that does the clamping.
    Note, if you've got an Ad-Block running in your browser, you may need to switch it off to see the above.
  3. Chalicekey
    24
    25
    North Carolina
  4. Mendel Leisk
    42,352
  5. Chalicekey
    24
    25
    North Carolina
    So you dont like them?
    ...... but will they work?
  6. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    you see that form on this page where you select your car for compatibility ?
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Ran into a couple of issues with this compatibility chart before, double check with another sources on large transactions.
  8. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    Don't do it man. I'm all for modifying cars but slapping on a few Universal mods like this on a an essentially start car just doesn't look right.
    First thing you should do is lower it
    James Powers likes this.
  9. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Lower it and just space out your OEMs until you are ready to go all in. Thats what Ive done. I have 10mm spacer in the rear and 5mm in the front. You dont need to get new lugs or new posts. You can get away with pushing out to 12mm in the rear and still have a good grip.
