Extended oil change intervals..
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Nov 13, 2007.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    10k mile update
    Hey guys... Just wanted to keep this thread current.
    I received my UOA from Blackstone from the 10k mile sample. They were impressed at how well the Mobil 1 was holding up and actually recommended another test at 12k miles. I've already done the change at 10k as originally planned so that point is moot.
    Argh! Can't get the dang PDF to attach to the thread. Seems to upload fine, but doesn't show up in my attachments list or the thread. If someone wants to see it send me a PM or e-mail and I'll send it to you.
  2. tochatihu
    tochatihu Senior Member
    9,982
    3,851
    Kunming Yunnan China
    2001 Prius
    Of course I want to see your UOA, Evan. I want to know why your wear metals are low among Prius!
    Did you switch to synthetic at a very low odometer, or do a very early 1st oil change? I forgot.
    I wonder if block heaters, foam tubes etc. might actually ever so slightly reduce cold-start wear.
    I guess you don't use the K&N engine air filter; the one with the big-a$$ holes (might have to let go of that experiment, someday)
    My only concern with these long oil change intervals (when supported by UOA) is that they might allow you to ignore visual inspections of all those safety-related systems under the car. It is good to get down there every 4k. Sooner if you can stand it.
  3. efusco
    19,891
    1,196
    Nixa, MO
    Yes, I switched to synthetic at about 2000 miles...ditching the first stuff right away and figuring I'd get rid of those early wear metals ASAP. I did run one 5000 segment with mineral oil b/c the dealer, trying to be nice for some other issues, gave me a free unnecessary oil change. Otherwise I've used Mobil 1 for 63k of the 70k lifetime miles.
    I, too, wonder if the EBH might not be helping reduce those cold start wear issues.
    I DO use the K&N filter and have for the past 40K miles...put that in your theory pipe and smoke it!
    I'm going to try again to upload the UOA, if it doesn't work shoot me an e-mail (evanfusco AT AOL ). OK, I keep getting a message that I've exceeded my upload limit and can't extend it (my moderator powers apparently don't extend to that)...shoot me an e-mail.
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    What was you TBN in other reports? I keep wanting to see if Mobil One 5W-30 tracks lower than other synthetics. 2.4 seems low compared to others.
  5. tochatihu
    9,982
    3,851
    2001 Prius
    Evan all I can say about the K&N air filter is that I do use it and I do have a little higher Si and maybe-above-measurement-uncertainty higher Fe and Al. Not enough different to suppose that a wear scar has actually been created on some contact surface, but enough to watch in the future.
    People who hate K&N *really* hate them. But I am just trying to understand the long term risk. The long term benefit is already clear: Not a pile of discarded paper airfilters, and a few hundred $.
    My K&N has experienced some atypical events because I do (did) drive on the unpaved roads. Very very unpaved. But whenever possible I would lift the accel (and shut off the gas engine) when a Jeep + dustcloud approached from the opposite direction. That should help. But ultimately, we are talking about one wear scar caused by one 'lucky' sand grain that gets through and hits metal 'just right' before the oil filter catches it.
  6. efusco
    19,891
    1,196
    Nixa, MO
    TBN at 7700 miles was 3.3.
  7. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Thanks. I will continue to follow.
  8. gazz
    gazz Member
    216
    Coventry, UK
    I know I have said this few times but in the UK we go 10K-20K between changes. Surly if you use Mobile 1 10K should be no problem if its the same oil we have. 10K is standard oil change in the UK form the Prius. Gm cars I think are 20K.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Sadly, the API American Petroleum Institute has such weak standards, and has so badly brainwashed the average motorist, that folks shiver in fear if they think they have more than 3,000 miles on their oil
    When I mention certain cars with LongLife service oils that allow 24 months or 30,000 miles, folks here go insane. Some even claim if they lived in the EU they would STILL change the oil every 3,000 miles!
    Just sit back, have a Pint, and laugh. Works for me
  10. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    I just got my UOA from Blackstone - darned fast! Mailed it from Vermont on Sat, got results in email today!!
    I'll try to attach it but in case it doesn't work:
    I've been using Mobil-1 5-30 since the 10K change, changed every 5K until this sample. This is the first time I have ever had a UOA.
    Engine miles: 62,421
    Oil miles: 7,400
    All numbers at 7,400 miles in line with averages
    TBN: 3.7 Their comment said anything < 1.0 is bad. Try 8,000 miles
    Heck with that, I can make at least 10,000 :) Evan's car had a TBN of 3.3 at 7,700 miles and 2.4 at 10,000 miles. Blackstone suggested he go to 12,000. Glad I finally got around to mailing in the sample (took it in March when I changed the oil). I'm coming up on 7,500 on the oil already.
  11. drees
    drees Senior Member
    1,782
    247
    Make sure you don't focus on the TBN, but also look at wear metals, flash point and insolubles.
    Just because the oil has a good TBN left, doesn't mean that you should run the oil longer.
    In your case, it looks pretty good, though I am slightly concerned by the trace of fuel and low flash point. What was your driving patterns over the OCI?
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    From what I have seen, Blackstone is very good at looking at the "whole picture" for oil analysis. They don't just focus on TBN
