Extended Warranty for the Combination Meter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pria2005, Mar 11, 2015.
  1. Have been denied the extended warranty of the combination meter
    5 vote(s)
    100.0%
  2. Have not been denied the extended warranty of the combination meter
    0 vote(s)
    0.0%
  1. Pria2005
    Pria2005 New Member
    Flagstaff
    I'm one year past the 9 year extended warranty of the combination meter of my prius and have unfortunately been denied a Goodwill warranty to repair this part that has been faulty since 2012 (which was the same time they initiated the extended the warranty in the fall of 2012.) The warranty enhancement covers this failure for a period of the longer of 9 years from date of first use (DOFU) (no mileage limit) or before September 30, 2013 (which ever is longer for the condition described).
    Technically I was in the shop to address this concern before 2013, but two of the dealerships I went to were unaware of such an issue and did not fix it. I only recently discovered through my own research that 3% of Prius owners experience this same problem. Has anyone else experienced difficulty in obtaining the extended warranty coverage for their Prius?
    I could not attach the document but here is a link to the warranty for others having issues with their dash lights going out: file:///C:/Users/ksieb/Downloads/114901842-Prius-Combination-Meter-Warranty-Extension.pdf
  2. janetjanetbobanet
    janetjanetbobanet Junior Member
    52
    Wichita, Kansas
    I am being denied warranty coverage for mine, which quit working in the middle of driving on the interstate last night. I am fighting it by filing a complant with the NHTSA. To stop covering a known safety defect is wrong, in my opinion..
  3. JC91006
    16,477
    8,394
    As a safety issue, I guess you can say you can't shut the car down while it's parked in your attached garage.
  4. JC91006
    16,477
    8,394
    this is only suppose to occur in a cold climate. Is it cold where you're at now?
  5. bisco
    49,387
    are all safety items warrantied for life against defects?
    SageBrush likes this.
  6. JC91006
    16,477
    8,394
    the problem here is there is a known defect and a specific time frame for the defect to occur. This is not an (if) it'll occur defect, it's a (when) it'll occur defect. What should've happen is a recall for this item but Toyota weaseled out of this by offering a 9 year warranty and then leaving it up to the owners afterwards.
  7. bisco
    49,387
    how do we know all this?
  8. JC91006
    16,477
    8,394
    know what? they weaseled themselves into giving a 9 year warranty? because that's what we have here....and not a full blown recall
  9. bisco
    49,387
    how do we know they will all fail, and at a certain point?
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
  11. SageBrush
    11,627
    2,530
    Southwest Colorado
    What is not a safety item in a car ?
    "The worn plastic distracts me from driving."
    "When my engine overheats my loses control."
  12. JC91006
    16,477
    8,394
    because it's happening slowly, one by one as the mileage increases
  13. bisco
    49,387
    true, but we have no idea how many or what percentage. or even that they will all die eventually. could just be a bad batch.
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    What part is immortal ? JC's reasoning is silly
  15. JC91006
    16,477
    8,394
    if you look at the TSB on the VIN number this covers.....it's a VERY big bad batch
  16. bisco
    49,387
    okay, can't argue with that. that's the m.o. for all car companies, i think 9 years may be unprecedented.
  17. SageBrush
    11,627
    2,530
    Southwest Colorado
    Sure you can. The inverter story is similar.
  18. bisco
    49,387
    i can't argue that it's a big batch, because i don't know how big. and even if i did, it's a subjective judgement.
    i've never really understood the reasoning, where if a lot of people are harmed, they should receive something that wouldn't be given if only a few are harmed. it feels more like political correctness than anything else.
  19. JC91006
    16,477
    8,394
    well since you're asking
    start vin finish vin
    2004
    KB20U 0001009 - 0116870
    KB22U 0001142 - 0116845
    2005
    KB20U
    0116874 0133248
    3000000 3128076
    7003414 7057937
    KB22U
    0116872 0133240
    3000008 3128067
    7004342 7057888
    2006
    KB20U
    3099688 3202428
    7057941 7545074
    KB22U
    3128082 3202418
    7056471 7544598
    2007
    KB20U
    3201067 3296439
    7083497 7694891
    2008
    KB20U
    3291973 3462539
    7690436 7818544
    2009
    KB20U 3458507 3546425
  20. bisco
    49,387
    would it be easier to quantify the numbers not represented?:cool:
    and this was the 'dealer doesn't have to see it, if you say it happened, they have to replace it'?
    9 years, meaning the 2006's are starting to go out of warranty?
