Extended wheel Studs 2012 need help
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Crixus, Nov 30, 2020.
  1. Crixus
    Crixus Junior Member
    16
    New York
    So I managed to snag at auction a set of Scion FRS 17in wheels 5x100 bolt pattern, I'm running a 5mm spacer due to clearance, and they fit. However I need ever so slightly longer Wheel Studs. Extra 10mm should suffice. However after spending a couple of hours combing the internet I can't find much.
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    they're out of stock right now, but at least you know what to look for /
    Security Check
  3. Jchoi808
    Jchoi808 Member
    30
    25
    Mililani, HI
    2018 Prius Prime
    I have the 3mm spacer on the stock studs with those same wheels and haven't had a problem so far. Been on the car for 3+ years now.
    Crixus likes this.
