Extending Range - Adding Aux Fuel Tank
Discussion in 'Gen 2 Prius Technical Discussion' started by faith2walk, Apr 21, 2007.
  1. DFWPrius
    DFWPrius New Member
    Hurst, TX
    I have seen a posting from someone that has a roof rack, some for bicyles and others use the rack for
    things I don't recall. If you installed the roof rack and mounted one of the small pods on it, it could carry two, five gallon gas cans. It is lockable, it would stow the gas outside the car, the weight would in the center,
    it would raise the Center of Grav. a bit. It would raise your car's drag. Weight and drag might take 2 to 4 MPG off your avg.
    Remember each gallon of gas weights in at 6.8 lbs.
    10 gals 68 lbs.
    rack and pod 30lbs appox.
    2 gas cans 4lbs
    Total 102 lbs
  2. bwilson4web
    16,507
    <div class='quotetop'>QUOTE(faith2walk @ Apr 22 2007, 11:32 AM) [snapback]427799[/snapback]</div>
    If you are after a permanent installation, it looks like a reasonable start. Plumbing would be a challenge but not that big of a deal. If you take out the small tire, you'll probably find some 'drain plugs' in the bottom. You could route tubing through one of them but you'll need an external 'storage' area for the hose. Locate the bolt holes used for the shipping fixture, the ones used for the receiver hitches, and you can mount a small box to hold the hose.
    The fill remains a challenge. I'd prefer to have it out of the vehicle in some way that if there is a spill, nothing winds up in the cabin.
    I'm assuming you're after price-shopping on the road. I used a 5 gal can with my VW MicroBus and that worked out great. It only gave me an extra 150 mile range but that was enough to make a difference. I'd recommend trying the gas can approach first, to see what sort of savings before going after a permanent setup. I do remember gas prices in the western high plains could be pretty ugly.
    GOOD LUCK!
  3. Earthling
    Earthling New Member
    441
    Somewhere, NY
    <div class='quotetop'>QUOTE(bwilson4web @ Apr 23 2007, 09:48 PM) [snapback]428750[/snapback]</div>
    I'm a cheapskate, I admit it. But let's remember, we're talking a vehicle that gets from 45 mpg to 50+ mpg. So if you paid an extra 10 or 15 cents a gallon, so what?
    How would anyone expect to save enough by buying gas at the cheapest locations to pay for the installation of an extra fuel tank? Do some math.
    I once bought a cheapo car which had a non-standard fuel tank mounted in the trunk. Can anyone say "gas fumes?" Someone just about gave me the car, and I got rid of it two weeks later. Replacing the gas tank would have cost about 3 times what I paid for the car.
    I'd drive the Prius and be happy with the excellent fuel economy. Bob's idea of a Jerry can is probably the best, if you really wanted to pinch pennies with extra fuel. But then you'd have to dodge a full Jerry can flying around the cabin should you ever get in a wreck. Is it really worth that risk to save a few pennies?
    Just pay for the gas and don't worry about a couple extra cents here and there. In New York, we pay an extra 10 cents a gallon in taxes. Why worry about it? Check the fuel map to see what I mean, the one that shows gasoline prices nationwide.
    Harry
    <div class='quotetop'>QUOTE(DFWPrius @ Apr 23 2007, 05:20 PM) [snapback]428619[/snapback]</div>
    Well, that would be safer than carrying a can of gas in the car. But then the extra drag would cancel out any savings from buying gas 10 cents a gallon cheaper, so you haven't gained a thing...
    Harry
  4. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Faith2Walk, you didn't answer my question: Does your employer pay for your gas?
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Wow. That's one heck of a job ... what exactly does it involve,
    and why so much driving?
    _H*
  6. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(faith2walk @ Apr 22 2007, 08:58 AM) [snapback]427772[/snapback]</div>
    I know it's possible. I saw some pictures where the owner bought an A/C vent cover that has the shift knob, but the one from a Japanese model. That meant it replaced the vent cover on the right side of the MFD. They used the spot where the shift knob would go for the tach. I don't have a link, but it looked cool.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    sorry to be blunt, but i think you are crazy for even thinking about it.
    i must be dense, but in a car that gets a 3-500 mile range and you have issues because gas stations are 60 miles apart?
    other than a professionally installed tank that would no doubt cost thousands, any other option would be incredibly foolish.
    otoh, i would really like to know why you have opted to drive all these places? sure i can see running to the UP and what not, but a 1100 mile trip. you would rather spend 20 hours driving it? im not sure i would do your job for any amount of money. i like to drive and have taken several dozen car trips of 2000 miles or more including a 4500 mile trip to Alaska, but to do as part of a job?, no way... fly me or get someone else
  8. alexstarfire
    alexstarfire New Member
    220
    <div class='quotetop'>QUOTE(Per @ Apr 23 2007, 11:24 AM) [snapback]428337[/snapback]</div>
    You do realize that the European gas tank holds the same amount of gas as the US ones? They just use a differt sized "gallon." You can look it up in the manual.
    Or am I just crazy?
  9. bwilson4web
    16,507
    <div class='quotetop'>QUOTE(faith2walk @ Apr 22 2007, 10:58 AM) [snapback]427772[/snapback]</div>
    I don't have the reference handy by Hobbit posted a technical description of tachometer installation for the Prius recently. You might "PM" him (or he might spy this note.) There is another approach I've been thinking about:
    Frequency counting DVM
    You might be able to score a frequency counting DVM that could measure ignition pulses from the engine ECU. You'd have to multiply the frequency by two, the ignition fires every other rotation, but it might be an affordable way to get started. After you get a 'hang' of the sweet spot, you'll have a nice instrument to use for other 'things.'
  10. faith2walk
    faith2walk Upgraded again
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(Earthling @ Apr 23 2007, 10:39 PM) [snapback]428794[/snapback]</div>
    Well...for the average Prius driver that may be true, but when I spend $400/month on fuel, and the differences in prices are $0.25-$0.40/gal, it can mean quite a bit. My questions were not meant for creating a change that everyone would need, since most don't travel as often, as far (distance), as long (time), as I do.
    <div class='quotetop'>QUOTE(Rick Auricchio @ Apr 23 2007, 11:07 PM) [snapback]428811[/snapback]</div>
    No direct compensation, it's part of the pay package. Long mileage/road time assumed.
    <div class='quotetop'>QUOTE(hobbit @ Apr 23 2007, 11:57 PM) [snapback]428835[/snapback]</div>
    Contracts with 42 individual electronics providers (Dell, HP, Getronics, IBM, etc) for warranty service repair, and UPS Logistics warehouses the parts (8 warehouse in MI alone, but all states have them).
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Apr 24 2007, 12:47 AM) [snapback]428860[/snapback]</div>
    The jobs are time sensitive and are piggybacked...when each job is finished, we are reassigned. If I am already 3+ hours from home, then I almost automatically take another assignment, but it also depends on if I am the closest specialist. There are times when I am gone for 3 days straight, that's why I keep an overnight (or 2) bag with me and so many emergency items/fluids.
    It's a rotten job and I am also taking online courses to make a career change. It was meant for someone who has no life, but right now it's better than mickey D's, and that's about all you can get in MI since the massive layoffs. So much competition that it's not even funny anymore.
  11. faith2walk
    154
    Alpena, MI
    Just talked to a guy briefly about doing a custom fit with one of these tanks, and he said it would probably be about $350 for labor, which would include removing the storage about the spare tire, and mounting (with some body work) the tank below that. Then running the fill spout to a spot just below the current factory fill location. He also mentioned the possibility of doing it inline, but mentioned I would have to use the aux tank first because if the main tank ran out of fuel the onboard computer would go haywire and might cause some serious error codes if I tried to drive too many miles...might eventually stop the car. He didn't know cause he has never work with a "smart" car. Most of the jobs he's done were pick-ups with bed tanks.
    Still not sure I am willing to do it. Going to sit and cogitate over it.
  12. hobbit
    4,089
    469
    Bahstahn
    tach: http://techno-fandom.org/~hobbit/cars/tachack/
    Relevant to the subject "Extending Range" simply because if you
    drive in the sweet spot RPM as much as possible, you'll get more
    range without the "mad max" pair of 55-gal drums sticking out the
    back of the car...
    _H*
  13. bwilson4web
    16,507
    <div class='quotetop'>QUOTE(faith2walk @ Apr 24 2007, 08:32 PM) [snapback]429444[/snapback]</div>
    I think the tank series is risky:
    http://priuschat.com/the-gas-bladder-exposed-t31545.html
  14. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Faith, thanks for clarifying the job info. I can see why you want to save fuel cost. But if you're not reimbursed for actual fuel costs, won't rising fuel cost eventually end up becoming a pay cut?
    I would NOT let that $350 guy touch your Prius under any circumstances! NO NO NO! He has no idea about the bladder system, the extensive fuel-vapor leakage tests the system does, etc. He's thinking it's just like a big ol' pickup truck.
    There's not going to be an easy way to have the aux tank feed the main tank, unless you remove the filler from the main tank. But that won't work, because vapor is supposed to go up the filler to the capture system.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    Faith, i can now more understand your position. i am fairly familiar with your area and its economic woes are monumental. (i left that area after the 2nd major rounds of auto layoffs. that was nearly 800,000 UAW ago so, its only gotten worse) also, the UP is legendary for high gas prices and its been that way since waaay before the first oil embargo.
    but said it once and will say it again. your best bet is to go to a reputable mechanic who can completely redesign your current tank and replace it. now what kind of computer hell this will cause, i dont know. what you should really do is nothing. enjoy what you have. take advantage of every cheap gas opportunity you see, even if you have 8 bars left.
  16. faith2walk
    154
    Alpena, MI
    <div class='quotetop'>QUOTE(Rick Auricchio @ Apr 26 2007, 11:27 AM) [snapback]430504[/snapback]</div>
    Recently they have started adding a fuel surcharge/miles to help compensate, but it's not in the contract. It's more like a bonus. (whatever that is, sarcasm)
    As I mentioned earlier, I am pretty convinced this is more work than it's worth. Thanks for the advice.
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Apr 26 2007, 11:52 AM) [snapback]430530[/snapback]</div>
    That was the problem this body shop guy guaranteed(computer)...that is the reason why he suggested not touching the main tank. If he was going to do anything, he promised it would be to leave the system no worse than it already is. He mentioned that it may be a great idea for evaporative emissions to have a bladder, but, in his opinion it was way too complicated for what it was trying to accomplish.
    Either way, I've gained info from it, but that's all.
  17. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I guess I'll be the voice of optimism here. This is not difficult, we've been doing this type of thing with diesels for decades. There are several established companies in the diesel community that build kits to add an additional fuel tank to your vehicle. In diesels, these are used to run straight vegetable oil (SVO). The kits include a tank, fuel lines, fuel filter, fittings, and the switches and solenoids to switch from one tank to the other. The SVO kits also include heaters to keep the SVO from gelling and clogging your fuel lines and injectors.
    Check out www.greasecar.com Their kit for my car, a 2003 Jetta Wagon, is $995 and includes an aluminum 13 gallon fuel tank that fits in the spare tire well. They may be able to mix and match to find something that will work for you.
    Of course this doesn't make sense, cents?, financially. Even at a savings of $0.20 per gallon you would have to purchase 5000 gallons of fuel to pay for the price of the kit. At 45 mpg that is 225,000 miles of driving.
    It makes more sense when you can run on free waste SVO from a fast food joint. Then it is only 3000 miles to break even.
  18. bwilson4web
    16,507
    I hate to say this but it almost sounds like there might be a business opportunity . . . shipping gasoline to that area and reselling it. Get a couple of rail tankers full of gas, park them in the heart of the most expensive areas and then sell discount gas directly from the tanks.
  19. gator1976
    gator1976 Junior Member
    illinois
    Heres what I did,
    I went to our local farm store and purchased a 15gal. Sprayer tank it was on sale 59.99
    7' of 1/4" hard line
    A ball valve for spraying, came in a 2pk. 7.99
    A pack of sprayer clamps, you can use regular hose clamps up to 4.00
    2' of 1/4" gas line 2.35
    The tank comes with accessories to plug the drain hole and tether the cap to the body, aswell as alligator clamps for power. It does not come with a good sealing lid that's where the 2' of gas line comes in. cut it down to fit in the inner ring then slice it in half long ways to make it fit the lip for a seal.
    I hooked the clamps to the 12v battery and routed the wires under the rug to between the seat and tank.. do the same with the hard line and rout it through the breather hole about 1" deep in the lid. And run it between the crack in the body and bumper.
    Cut the sprayer line about 7 to 8' and put one end on the pump using supplied hose clamp put a valve on the other end using the sprayer clamp or hose clamp, then about 5 to 8'' on the other side using g another clamp. The shorter hose is what will go in the filler line on car tank .
    Then fill the tank..
    The first use you will need to dispose of about a pint of gasoline as the pump contains liquid from testing.
    Good luck
    I estimated I will have approx. 2000 +- 20190620_123413.jpg 20190620_123434.jpg 20190620_123714.jpg 20190620_123801.jpg 20190620_123517.jpg miles per full fillip of both tanks 20190620_123413.jpg 20190620_123434.jpg 20190620_123714.jpg 20190620_123801.jpg 20190620_123517.jpg 20190620_123607.jpg
  20. bisco
    52,742
