Extension Cord Possibilities
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DSMM6, Aug 21, 2013.
  1. DSMM6
    DSMM6 Junior Member
    24
    2013 Prius Plug-in
    I think I'm making this decision way harder than I need to, but I have an outlet in my garage that is installed on a 20 amp breaker and I want to use it to charge my Prius. However, the outlet is on the back wall and I can't park in the garage. I stretched the charging cord from the wall and it makes it right to the garage door, so my first thought is to get a very short cord, maybe 6 feet, to get it to my car. My dilemma is I have been looking for a less than 10 foot extension cord that is 10 gauge and rated at 20 amps and I can't find one that is 3 pronge so I can plug it in to the wall. There are 12 gauge 15 amp cords everywhere, but I was thinking that since I have a 20 amp breaker, I should have a 20 amp cord. Also, I thought 10 gauge would be better to hand any heat produced better than a 12 gauge. Is my thinking off base? Would it be better to just bite the bullet and run another outlet from the breaker box to the outside of the house, so I don't need an extension cord? And if I'm going through the trouble of running a new outlet, is it just as easy to run a 240 instead of a 110 or 120, so if I get my charging cord modified, I can charge in 1.5 hours instead of 3? Sorry for a lot of questions, but I thought this would be a good place to get opinions. I was thinking to get an extension cord in the interim and ultimately, I would like to be able to charge in 1.5 hours, but it's a want, not a need. My Dad, the electrician says it's not necessary. Thanks for reading.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. powerplay
    powerplay Junior Member
    FL
    If your Dad is an electrician, why not just buy a short length of 10/2 with ground, SJO and put the outlet and plug on the ends. That way you can make it whatever length you need. Black wire goes under the brass screw, white goes under the silver and green under the green. Just make sure you buy the plug and outlet that accommodates the 10awg cable. I am sure your Dad can confirm with his thoughts.
  4. jnet
    jnet Member
    196
    32
    If you use 220v, it's more efficient because the battery is over 200v. If you use 110v, the charging system has to step up the voltage. In the long run, you're better off using 220v. For now, I don't see why you couldn't use an extension cord if you cord is thick enough. If you think about it, the wires inside your walls that run from the panel to the outlet is sort of like an extension cord. It's just an extension cord you can't see.
    The bottom line is that I never had any problem using extension cords as long as the wire is thick enough for the job. 10 gauge should be thick enough for you but the first time you use it, keep a close watch on the cord temperature, if it gets too hot, then you'll need something thicker.
  5. DSMM6
    DSMM6 Junior Member
    24
    2013 Prius Plug-in
    Thanks powerplay, I hadn't talked to Dad about making a cord, just running a new outlet, so I will run this by him.
  6. ETC(SS)
    7,555
    You're over thinking it.
    There are a lot of Pip owners that use extension cords to charge their cars, and I've seen at least one video review where the reviewer did so as well.
    I can't speak for Toyota, but I think that the warning not to use extension cords is lawyer inspired. You're not powering an unlicensed Nuclear Accelerator. It's a charger that IIRC draws about 12-amps.
    You have at least three areas of concern:
    The Outlet.....you say that it is installed on a 20 amp breaker. Is there anything else that's powered by this circuit and is the wiring in your house done to code? If you have a 20-amp breaker protecting a circuit that's been wired with 16AWG wire (small).....you're not really going to want to sleep in the house while you're charging the Prius, especially if there's a refrigerator, a freezer, and a couple of incandescent exterior lights on the same circuit. ;)
    If it really is a 20-amp circuit and there's not much else on the same circuit then you have more than enough overhead to charge your pip.
    The Extension cord....shorter and thicker is better, but you're not going to have any problem using a 10-foot, 10 gauge cord...trust me. There are pip owners driving right now with 100' 14g extension cords so that they can steal electricity from parking garages, employer's exterior outlets, etc. If it's a new cord and it's in good condition you'll be more than fine with a 10-foot cord rated at 20A.
    The Weather....Is your garage outlet a GFI outlet? How about the extension cord? Where do you live? (that's rhetorical....I really don't care!)
    Obviously if you live where it rains or even snows a lot you'll want to be careful about plugging the pip in to charge, but if there's a carport in front of your garage or a 4' overhang then you're probably golden as well.
    See how much it would be in your area to install an exterior outlet....either in 110 or 220. If you live in the county and can DIY (or get Pop to do it) then you're only looking at parts...maybe a few hundred all in...IF you do it right. If the breaker panel in in the garage (many are) and you're good at pulling wire maybe even cheaper!
    If you live in a more 'civilized' area where you have to pay graft for pretend inspections and permits then having an additional exterior outlet installed can very quickly rocket into four-figures----but that's what you get for living the big city life. :)
    Short answer: Get the 10' 10AWG cord and try it out. Some of these are equipped with a GFI protector which is even better.
    If it trips the breaker, investigate other loads (things plugged in) on the circuit. Don't run screaming to the fire department if the breaker trips. That's what they're for.
    Good Luck!
  7. Gruvin2
    Gruvin2 Junior Member
    45
    16
    Baltimore, MD
    FWIW I have used a 150' standard outdoor extension cord for charging. Without looking at it i believe it was 12-14 gauge and rated for 10-12 volts. Charged my PiP without issue.
    This is my personal experience and risk. I know Toyota does not recommend using an extension cord.
  8. DSMM6
    DSMM6 Junior Member
    24
    2013 Prius Plug-in
    The outlet is the only thing on that circuit. We ran the new outlet to the garage because I kept tripping the breaker that runs the rest of the garage outlets when I would run my pancake air compressor to fill my tires up. Not sure what size wire we ran, but I trust that Dad picked something appropriate. It is a dual outlet where I have a fridge plugged in, but I could move it if need be. I am having trouble finding a 10 ft 10 gauge cord, so I may make one as suggested above. The weather is avoidable. I think we could run another circuit from the breaker box, since my basement is unfinished, just not sure what I would need for 220 like I would like to have if I go through running another outlet. It's convincing Dad to come over to help me. :)
  9. ETC(SS)
    7,555
    ^ You may or may not have to move the fridge.
    Me?
    I'd try to charge the pip with it in place. If your Dad is halfway competent, the 20A circuit is fine for both and I think that you'll have enough overhead on the circuit to run the fridge and the pip.
    Pruis owners tend to worry about stuff too much.
    Go to a Big Box store and get a heavy duty extension cord in as short a length as they offer. Do some internet shopping. Even a 25' 10AWG cord is fine for this application....IMHO.
    Your car draws about 12A while charging.
    The wire that's hooked to your garage outlet is probably 12AWG (which is smaller) and probably longer than 10'. It's not that hard, really.
    The problems start happening when you combine small wire with long lengths, an exterior location and an overloaded, non-protected circuit.
    You're going to be OK....really.
    Besides...you have a smoke detector and fire insurance, right? :)
    Good Luck!
  10. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Best to run a separate dedicated circuit with GFI to the exact location where you park. Chances are, you'll only pay for materials. Should be inexpensive. If you have a Harbor Freight in your area, give them a call. I was at one recently and I believe they have a 10 gauge extension cord , short length.
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    IMO, you don't need a GFCI circuit. The EVSE already has such a circuit in the brick in the cord.
    Don't overthink this. But do be cautious when you first use whatever extension cord you get. After 20-30 minutes of charging touch the cord and see how warm it is getting. Yes it will be a bit warm, but is it too hot to hold? Yes...then stop using it. No, the it is OK. Make sure you don't use a cord that is too long and coil it up partially. The coils thermally insulate each other and add to the destruction of the insulation over time. I think it is better to get a fatter longer cord than a thinner shorter one. Don't run the cord under a rug, for example.
    Don't bother with 240v L2 charging circuit. You'll never save enough on the difference (in a PIP) to pay for it. Wait and see for your next car.
    Mike
    markabele likes this.
  12. bisco
    52,855
    search here for extension cord threads. they're quite extensive and illuminating.
  13. markabele
    5,084
    1,782
    Nebraska
    Well said, Mike.
  14. DSMM6
    DSMM6 Junior Member
    24
    2013 Prius Plug-in
    I really appreciate the feedback. I actually found a six foot 12 awg 15 amp cord over at my Mom's yesterday, so I'm going to try that tonight. I think I've seen on here that the charging cord only draws about 12 amps anyway, so I suppose that cord will work. As well as plenty of people on here seem to use whatever cord they feel like.
    My Dad said he wasn't keen on doing a 220 or 240 as you point out Mike, either. So, I think I'll run the extension cord for a little while until I can get the time to run a dedicated line and install an outdoor receptacle. I suppose another 20 amp breaker would do the trick. Dad will know. I have a generator plug already on the exterior wall next to my garage door, which they used metal conduit to run inside my garage to the breaker box in the basement, so I could just follow the same route. Thanks again everybody!
  15. Ian Mayo
    Ian Mayo Junior Member
    32
    Don't forget that in the UK we have 230V as standard. Charging in 90 minutes is normal and lets us do a run, charge over morning tea, a run, charge over lunch, a run, charge over high tea, a run................
  16. DSMM6
    DSMM6 Junior Member
    24
    2013 Prius Plug-in
    That's why I thought it would be cool to be able to charge in 90 minutes. I could get home from work, charge up, go to the kid's practices on electric alone, and then charge up again at night for my daily work commute. But, I don't know.
  17. DSMM6
    DSMM6 Junior Member
    24
    2013 Prius Plug-in
    I bought my car a month ago today. I've got over 6,000 miles on it and I've only got 1% EV mode. Very happy with averaging 59 mpg though, according to the car. I haven't done the real math. My 2006 Focus I traded in got 32 mpg and took about $38 to fill it up. I can fill my PPI for $28.:)
  18. Zimmy 1
    Zimmy 1 Junior Member
    61
    Smithtown NY
  19. DSMM6
    DSMM6 Junior Member
    24
    2013 Prius Plug-in
    Hey Ian, do the PPIs over there come with a charging cord ready to handle the 230v? I've heard that if in the US you want to charge in 90 minutes, we have to get our cords modified to handle the extra juice. Just thought if the European PPI already has one, may you can buy one ready to roll instead of modifying your existing one.
  20. Ian Mayo
    32
