Extension Cord Possibilities
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DSMM6, Aug 21, 2013.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I used a 25' 12 AWG extension cord with my OEM EVSE for the longest time, and had no issues. When it comes to EVSEs, you do NOT want GFCI, as it can be tripped too easily, in fact, Leviton sells a special EVSE friendly GFCI outlet, but most OEM EVSEs have built-in GFCI protection anyways.
    If you want the option to charge at Level 2, but want to keep it cheap, I highly recommend you upgrade your OEM EVSE via EVSEUpgrade.com. This would let you charge at Level 1, Level 2, using several types of plugs.
    When you are ready to sell the car, you could easily sell the upgraded unit to another member, so you wouldn't take a big hit on it, or you can just keep it, and use it with your next EV.
  2. markabele
    5,084
    1,782
    Nebraska
    I second that.
    I was plugged in at a campground recently. It was the only thing plugged in and it kept tripping...so annoying.
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    markabele likes this.
  4. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Exactly what I was going to say. Places like Home Depot will sell electrical cord by the foot in various gauges and number of wires. They also sell both male and female plug ends. I'd get the lowest gauge that works with the beefiest plugs that you can get.
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    That is exactly what I did. I got 10 feet of 12 gauge 3 wire cord, two beefy connectors (one male and one female), and made my own extension cord.
    Lourun likes this.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    A useful item at Harbor Freightis a kilowatt meter. It will check your open supply voltage, tell you if your cord Is dropping voltage, look at your load and tell you the final voltage to thecar while charging and the current draw as well as the wattage . Since your Dad is a electrician , a outlet with one of 220 and one of 110 would be nice. The main thing is you must have a EVSE and brick modified to accommodate 220, once modified it will accept both. I have used outlets that are low, 105-108 volts, the only difference is a slightly longer charge time. When I am at my sons house he runs about a 10 gauge cord 150ft and it charges fine. I do check it with my Watt Meter tho.
  7. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    There is one simple option I don't think I've seen addressed here. Get together with your father on a Saturday. Working under his supervision run a piece of steel conduit from your garage box up the the point on the outside closest to where you park. Put in a length of 10 gauge, and a weather resistant outlet on the end. Don't let your dad actually do the work, you won't learn anything. He is there for the hard part, the judgment. Then take your dad out to dinner.
    Andyprius1 likes this.
  8. Andyprius1
    2,327
    859
    Cool CA
    Great advice !
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Nice post!
    Also I purchased 25 feet of 12 gauge wire, 15 amp braker, and a Heavey duty GFI plug. We ran a dedicated 110 outlet. It cost around $65 dollars. A electrician friend of mine and about 2 hours time to install. After the job was done the best time was had at the brew pub for burgers and a cold brew! :)
  10. dame94
    dame94 Junior Member
    32
    Brentwoodish, California lol
    2018 Prius Prime
    I don’t know about “stealing” electricity....
    But I just bought a Prime, and needed a 50’ 10 gauge so I got this one.... been charging outside for almost a week..... no problems. (https://www.amazon.com/Century-Contractor-Extension-Cord- extension/dp/B071LPYYVW?keywords=century+contractor+grade+50&qid=1534862401&sr=8-3&ref=mp_s_a_1_3 )
  11. dame94
    32
    2018 Prius Prime
    Please delete, didn’t realize how old the thread was, my apologies.
  12. ETC(SS)
    7,494
    BTDT.....
    The stealing electricity part is easy and binary.
    If you're paying for the electricity or you have permission from the person who is paying for the electricity?
    It's not stealing.
    FORTUNATELY.....plug in hybrids have been around for a while now and the vast majority of their owners do it legally and honorably......and......safely.
    50' of 10AWG is more than safe for your purposes....
    dame94 likes this.
