extension cord specs
Discussion in 'Prime Plug-in Charging' started by Pizza Driver, Dec 18, 2016.
  1. eluo
    eluo Member
    122
    71
    Commack, NY
    For those with Costco membership, you can pick up two 12/3 50' for $35. I don't have this particular set myself. Just notice the price is really good.
    priuscatprimeguy likes this.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I bought that set and have been charging through one of them for the last two weeks. I did do some temperature checks with an IR thermometer and everything stayed within 3°C of ambient after 3 hours of charging.
    bwilson4web and priuscatprimeguy like this.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    One comment for those who use long extension cord: do not use it rolled-up, unwind it before use.
    MTN, CatsAreGods and bisco like this.
  4. Lee Jay
    5,850
    4,036
    The reason for this is heat build-up where the strands overlap (possibly many times).
    So I tried it rolled up (just the last 15 feet) when I did my thermal test.
    I've also tested the 14AWG EVSE cord rolled and tied. Indeed, it's hottest under the tie, but only about 5°C hotter than the rest of the cable.
    Still a good practice to keep things open for reduction of heat.
  5. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The guy was just charging an EV @ 12 Amps. I do not know what gauge cord he used.
    Remember, EV charging is a long time use - each time.
    CatsAreGods and eluo like this.
  6. Lee Jay
    5,850
    4,036
    That's 14AWG x 100 feet. I know because I have the very same reel and cord.
    I had my 12AWG x 15 foot cord (15 feet of 50 feet) coiled up in open air on the floor, not on a big spool with overlapping layers like that.
    giora likes this.
  7. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I think that my 6 AWG, 20 foot cable can handle the load. I use it to connect my 8 kw (30 amp, 220v) generator to my house.
    JeffD
    bwilson4web likes this.
  8. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The photo above was not meant to hint that #14 AWG cord is no good for charging the Prime or the PiP at 120 V.
    Simply unwind it before use especially if it is a very long one used for short distance. Tightly packed on a reel is worst situation, heat generated simply cannot be adequately dissipated and temp. is creeping up, charging a car takes much longer than almost any other use. Temp. rise is not linear with time, wires' electrical resistance goes up with temp.
    #28 giora, May 3, 2017
    Lee Jay and eluo like this.
  9. davidtm
    davidtm Member
    180
    TJ'ville
    Aw, but then you'll lose the induced magnetic field amplification! :p
    xliderider likes this.
  10. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    ... and in a pinch, it might work as an induction cook top.
    davidtm likes this.
  11. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Nothing (or almost nothing) to loose, it is not a single wire coil, "induced magnetic field amplification" is almost zero, induction from L1 is almost cancelled by induction from L2.
    Pinched or not, with induction cook heat is not generated at the cook top but rather inside the 'pot' bottom by eddy currents.
  12. davidtm
    davidtm Member
    180
    TJ'ville
    *kill joy*
    0PJA2 ?
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Nice escape:)
  14. xliderider
    8,140
    3,277
    Honolulu, HI
    You took my post way too literal, lol.
    It was posted in jest. ;)
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Point taken, my comment was clarification just in case someone...:)
  16. Trollbait
    12,800
    ...likes their meals smoked by scorched plastic.
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    OK nice as a joke (induction cook will not heat your meal on a plastic plate (and not the plate)...
  18. poohbear1953
    poohbear1953 Junior Member
    27
    26
    provo,ut
    any problem running extension cord , w/12 awg , from garage to laundry room drier 220 outlet , about 40 feet ? it doesn't have gfi ...
  19. Lee Jay
    5,850
    4,036
    This situation results in the cord's maximum temperature point being 15°F / 8°C above ambient temperature:
  20. clouds4brkfst
    clouds4brkfst New Member
    i just got a prius prime and after reading, i am still wondering which is the best extension cable to purchase to charge up the electric! Can someone link me to some good products? i have no knowledge of kwh, amps, volts etc. thank you
