Exterior bottom rattle noise
Discussion in 'Gen 3 Prius Main Forum' started by elmofongo, Mar 12, 2022.
  1. elmofongo
    elmofongo Member
    256
    SF, CA
    I’m trying to diagnose an external rattle sound coming from underneath front/mid area whenever I drive on a bumpy road. 2013 Prius Persona with 90K miles.
    Any suggestions?
  2. JC91006
    16,936
    8,647
    Only way to do this is to lift the car in the air and see if there's anything loose/missing.
    elmofongo likes this.
  3. ToyXW
    ToyXW Active Member
    153
    149
    Sacramento
    If it happens when one side hits a bump but not the other, check the sway bar bushings & end links.
    #3 ToyXW, Mar 12, 2022
    elmofongo and james nancy like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Check out the exhaust shielding... First step is shake exhaust pipe at back of car super hard to "adjust" the shielding. Don't worry, the rubber mounts will ensure you don't break anything.
