1. Rhunter
    Rhunter Junior Member
    38
    VA
    Greetings,
    I just reconditioned the HV battery in my gen2 prius. Upon reassembly, I ended up with the extra bolt pictured below. It's most similar to the bolts that fasten the HV battery to the vehicle, but It doesn't match any of the other 12mm bolts, so I had no idea where to put it. Anyone know where it goes?
  2. JC91006
    16,930
    8,639
    Don't worry about it, it's the one mounting bolt on the driver's side that's closest to the ECU compartment. It may be an identifying bolt for Toyota to see if it's been removed before........But you still shouldn't have an extra one. That would mean a mounting bolt is missing somewhere else.
    #2 JC91006, May 15, 2016
    Rhunter and S Keith like this.
  3. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Agreed. You likely missed one in the side brackets.
    Rhunter likes this.
  4. Rhunter
    38
    VA
    Thanks, guys.
