Extra charging cable
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Diddlywop, Jun 7, 2012.
  1. Johnny_D
    Johnny_D New Member
    Suitcase combo lock through the hole that is already there in the silver part of the blue handle. No its not foolproof but it may deter someone. If you get one make sure it has a 1/8" shank or smaller. I had to use an 1/8" drill bit to enlarge the hole probably 1/16 th. this solution seemed obvious to me. I use it every time
    On Amazon, $5 free shipping with Prime
    Amazon.com: Master Lock 647D Set-Your-Own Combination Luggage Lock, 1-3/16-Inch: Home Improvement
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Securing the charging cable | PriusChat
    Photos of locking to the tire in the link above.
    DianneWhitmire likes this.
  3. wiggleman
    wiggleman Junior Member
    86
    Arlington VA
    2015 Prius Plug-in
    I just made a new extension cable. I had a 20-foot 15A cable ($1/foot) cut at Home Despot, which is the same gauge as the charging cable. There I bought a good set of 15A plug and connector by Pess & Seymour (red box, $7.99 each) which light up when connected. I take it with me wherever I go, but admittedly it does take up room in the "spare tire box".
    52,854
    well done wig!
  5. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
  6. bisco
    52,854
    all of everyone's stuff is made in china.:rolleyes:
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Same here, that's the exact same one bought from the same place. Got my normal 20% off and a free flashlight as well. (y)
  8. Home Depot sells a 3 digit combo that fits without drilling
  9. wiggleman
    86
    Arlington VA
    2015 Prius Plug-in
    I checked the prices of the pre-made ones extension cords. I just preferred making my own.
  10. This thread started out as extra charging cable, which got my attention, then evolved into a extension cable. An extension cable is simple but where do get the portion that plugs into the car and on the other end the block, which is the leak detector and reset, etc. Your home electric stove doesn't have all this safety and it draws a lot more amps. An extra cable would be nice. An extension cable is easy.
  11. mitch672
    1,077
    198
    Randolph, MA
    Andyprius, you can build one with the OpenEVSE project for about $500-$600, or you can buy one for $800-$900 (or more for the Toyota factory cable), but they are very pricey until the volume of EVs being produced/sold picks up a lot... Even the least expensive J-1772 male head on eBay is $135, and thats without the attached wiring.
    eBay J-1772 head, you could buy 10/3 (good for 30A max) or 12/3 (good for 20A max) SJO/SWO (jacketed) cable to connect to this (2 hots + groun for 240V or its 1 hot, neutral and ground for 120V), and use a separate 18-22AWG insulated wire taped to it for the "pilot" signal wire, that would be the least expensive way to get the J-1772 connector/cable part of the project:
    Electric Vehicle Plug J1772 Compliant | eBay
    OpenEVSE project, example of the one I built (which btw might be for sale, I need to build a 75A version)
    EVSE_by_mwolrich - open-evse - A portable EVSE built with an Open EVSE board. - Open Electric Vehicle Supply Equipment (EVSE) - Google Project Hosting
    Andyprius # 1 likes this.
  12. ralteredstates
    ralteredstates Junior Member
    24
    coastal Connecticut
    I got the Volt's EVSE and it does NOT work with the Prius plug in. Electronic timing is off. It is also poorly made. I am very disappointed since it only cost $360. Ended up getting a level 2 from Home Depot. Won't be portable but I will use the level 2 at work and take the well built Panasonic (toyota's) with me if I travel.
  13. Thanks Mitch, good info there. Really professional job too.
  14. Just park on the cable.
    wiggleman and ultraturtle like this.
  15. wiggleman
    86
    Arlington VA
    2015 Prius Plug-in
    Not a bad idea!
  16. wiggleman
    86
    Arlington VA
    2015 Prius Plug-in
    The idea of adding a luggage lock and securing it thru the little hole in the charging cable is not so bad, but you have to remember that it's still plastic, which can easily be broken. A little leverage will break the plastic. I want to buy a steel cable and thread it thru that hole or around the whole cable below the plug. Then secure that cable to a lock.
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
    I am no expert by any means, but I don't think it's a good Idea to park on the cable, over time I would think it could damage the cable. Check out http://john1701a. His web site has a good locking option!
  18. I didn't mean mashing the cable, just a little weight on the edge. How ever, for the long term it isn't a "best answer" I agree.
  19. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    I'm curious.
    Why would you need a 2nd one?
    If you keep yours in the car, in the back, where it belongs and the car is needed to be charged, pull it out.
    Why an extra?
  20. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Because you want to leave one at home always hooked up to power? And not have to pull it out constantly?
