Extra Charging cord
Discussion in 'Prime Main Forum (2017-2022)' started by panache, Apr 1, 2018.
  1. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    The Prime permits 8A draw, pg 123 owners manual. The charger is in the Prime. EVSE is on the wall. Have another glass of Cabernet Bisco.
    52,849
    understood, you are in a mood tonight.:p which one controls the draw?
  3. pineprius
    245
    134
    NC
    The Prime permits 8A draw, pg 123 owners manual. Prime has charger which controls draw. Just trying to help the newbies with 9 different manuals in Japanese indecipherable English.
    52,849
    so if the charger controls the draw, it doesn't matter if you use a 16 amp evse on a 15 amp circuit.
  5. pineprius
    245
    134
    NC
    Correct. I think we're getting to the bottom line here. The original thread asked for low cost options of 2 charging cords at 2 locations without a time constraint on charging time, without having to spend more money on hardware upgrades at his carport 15A circuit. The Prime solves the issue with just an 8A setting draw on the car software.
  6. bisco
    52,849
    and even the 12a is fine if his circuit supports it.
  7. panache
    panache Junior Member
    34
    Central Virginia
    Thanks for the constructive comments. The manual indeed is a handful to read and everything is cross referenced 20 times in different parts that one ends up going in long circles.
    One last question before I get one of those cheap 16 A rated "Duosida" chargers: Will the car draw 12 A or 16 A if I leave it at the MAX setting when plugged into 110 V? I understand setting the car to 8 A will be the best/safest choice, but if every once in a while need to go a bit faster, will it trip the circuit breaker to run at "MAX" charge setting? Or, is rather the car onboard charger throttled to 12 A max, at 110 V so that the rating of the EVSE does not matter? I cannot find anywhere in the manual what the current draw at MAX is.
    Per some comments I have seen on amazon, the onboard car charger limits the current to 12 A at 110 V so getting the 16 A cheapie EVSE would be fine, but I would like to confirm with users in this forum who may have actually measured this would be appreciated!
    Arctic_White likes this.
  8. pineprius
    245
    134
    NC
    I have not measured a cheapie EVSE 16A, only Toyota OEM. The Prime charger will draw 8A if that is what you set the car software. What I do know is if you have other draws on the same circuit, you may trip the 15A breaker, which is why I recommend the 8A setting in the Prime software. Each individual situation is unique. You cannot be assured of any unique electrical situation without proper evaluation by a qualified electrician.
    #28 pineprius, Apr 3, 2018
  9. Digloo2
    Digloo2 Active Member
    124
    132
    Phoenix, AZ
    I have a normal pair of 120V outlets in my driveway under the porch light that's there. I never gave the power rating any thought, and just plugged in the charger and charged the vehicle. Reading this thread, I decided to go out and look at the breaker and see what it's rated for. Turns out it's labeled "washer + light". I switched the breaker off and sure enough, the light went out. Ok, now for the power outlet.
    I grabbed shop light and plugged it in, then shut off the breaker. Yup, that outlet is on the circuit, too!
    So the plug I'm using to charge the car has a 15A breaker on it. I'm sure if I tried to do a load of wash while charging the car, it would trip the breaker, but by itself (with the LED porch light that draws something like 5W) it has not been a problem.
    It takes a bit over 5 hours to charge from "empty", so it's running at full throttle for what it can draw, as far as I can tell.
  10. panache
    34
    Central Virginia
    OK, I will go ahead and buy one of them cheap EVSEs and plug in my Kill A watt and see how much it draws and report back :)
  11. ttait
    ttait Active Member
    273
    163
    Southern California
    My DuoSida is still going strong after more than a year. I got it from Ali-Baba for $165 delivered. I'm still pleased with the purchase and would buy it again. And it will run at either 120V or 240V. I ran a 240V box from a sub-panel in the garage to the carport where I park my Prime. 12/3 romex. easy-peasey.
  12. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    What type of outlet did you use?
    iPhone ?
  13. bisco
    52,849
    i think you'll be fine with the cheap evse and 12amp setting. no harm if it trips the breaker, just switch it to 8 amps.
    no reason it should though, unless you have other stuff on the circuit that's being used at the same time.
  14. panache
    34
    Central Virginia
    Thanks, other than 2 lights (LED) and a robot mower that runs during the day (load during charge cycles is 200 W) only, then that should not interfere with nighttime charging of the Prius.
  15. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Modern construction has 20 amp receptacle circuits and 15 amp lighting circuits.
    We need to confirm that the charger inside the car controls the amperage (I think it does).
    We also need to be clear that these are not charging "cords." They are the EVSE, electric vehicle supply equipment or (portable) EV charging station, which are the special SAE J1772 plug, smart power supply, and special cable.
  16. bisco
    52,849
    electroengineur can probably confirm it for us.
  17. mczouav
    mczouav Member
    BE
    Quick warning. Do not use a reel while charching. It does not dissipate the heat and many cases of fires happened. Also i use a 14 gauge wire as extention. 16 gauge wire heats up a lot when charging at 12 amp.
  18. panache
    34
    Central Virginia
    So I went ahead and bought a Duosida cord. I plugged it in with my Kill-a-Watt in line:
    Charge nearly empty battery: 11.8 A, 1380 W
    With the Prime Stock Charger: 11.6 A 1370 W
    So seems the car onboard charger throttles the rate, not the EVSE.
  19. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Yes. The EVSE acts only as a concierge for the charging circuitry which is inside the vehicle. All the EVSE does is tell the vehicle's internal charging circuitry what the maximum amount of current the EVSE can provide and verify that the vehicle's charging circuitry wants to be connected to your premises wiring.
    Here is a generic block diagram:
    When plugged into the car, the EVSE receives a signal from the vehicle that the vehicle is ready to accept power. The EVSE then closes the contactors and allows power to flow (shown in red in the diagram above) from your house's premises wiring to the car's internal charger.
    If you are using a 240-volt EVSE unit plugged into 240-volt wiring, 240-volts flow into your vehicle; if you are using a 120-volt EVSE unit plugged into 120-volt wiring, 120-volts flow into your vehicle. It's up to your vehicle to figure out which voltage is being supplied and to adjust its demands accordingly.
    The EVSE also informs the vehicle of the maximum current which the EVSE can provide. The vehicle is then welcome to decided how much of that maximum which it wants. (Kind of like plugging in a lamp with a 15-watt bulb or one with a 150-watt bulb: the outlet doesn't care as long as it's not more than the premises wiring can supply without tripping the circuit breaker.)
    The EVSE also contains a GFCI (ground fault circuit interrupter) for purposes of safety.
    When you plug the J1772 connector into your vehicle, here's what happens:
    • the EVSE signals presence of AC input power
    • vehicle detects plug via proximity circuit (this prevents the vehicle driving away while connected)
    • control pilot functions begin
      • the EVSE detects the vehicle
      • the EVSE indicates to the vehicle that it's ready to supply energy
      • the EVSE informs the vehicle of the EVSE's maximum current capacity
    • vehicle requests energy flow
    • vehicle and EVSE continuously monitor continuity of safety ground
    • charge continues as determined by the vehicle
    • charge may be interrupted by disconnecting the plug from the vehicle
    You can read more here.
    #39 Old Bear, Apr 7, 2018
    Arctic_White, panache and albus like this.
