Extra Length: In Rear?
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, Mar 11, 2017.
  1. Trollbait
    12,800
    It is for storing the charge cable. So not unimportant.
  2. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Why would you want to carry a cable around ?
    I wouldn't want to be known as the electric moocher.
    bisco and Since2002 like this.
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Certainly it's hollow, right?
    iPhone ? Pro
  4. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    of course, but the thickness IMHO is striking
  5. mr88cet
    2,313
    1,335
    Austin, TX
    Oh, OK, presumably you're saying that the carbon-fiber sheet material (if it can be called that) from which it's made is very thick, not commenting upon the thickness of the door itself.
  6. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Every time you open it, it swings right past your head. You have too notice about how thick that door is.
    Sorta like modern refrigerator doors nowadays.
    mr88cet likes this.
  7. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    " mind if I borrow a cup of sugar? Oh and while you're getting it, is it okay if I plug my car into your outlet?"
    NR427 likes this.
  8. mr88cet
    2,313
    1,335
    Austin, TX
    Gotcha...
    iPhone ? Pro
  9. bisco
    52,756
    most ev drivers are serious moochers. toyota must have recognized this. if you go on charge point, they show every 120v outlet available. legal or not.
  10. Since2002
    936
    1,098
    Duluth, GA
    But of course besides mooching there could be situations like using a charge station. Or charging at work, although I suppose some would purchase a second cable for that. But then where do you store the second cable, I guess in the filing cabinet at your desk? Maybe the hatch storage would be more convenient to store the work charge cable. Of course you could always just keep it in a small bag, but at least there is a nice place to store it out of the way if needed.
  11. bisco
    52,756
    you could put it in with the spare tire.:)
  12. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    I am still impressed with the amount of rear leg room! The prime feels like a full size car compared to my volt
  13. bisco
    52,756
    that's what my wife said when we went for a test drive, very roomy back there.
  14. Trollbait
    12,800
    The EVSE and cable that comes with a plug in car is a portable one. So the manufacturer provides a place for it, which happens to also be where the tonneau can be stored on the Prime..
  15. Tideland Prius
    16,665
    It stores the tonneau cover (if you have the Advanced, the roller one can fit under there) as well as the charging cable.
    Here, there are EV parking spots with 120V outlets so you have to use your own cable.
  16. mr88cet
    2,313
    1,335
    Austin, TX
    It's probably fair to say that that slot can be used for either the tonneau cover, the charger cable, or whatever else you might find useful. I noticed that, in one of Optimus Prime's videos, he said he puts water bottles there. I'll probably put my first-aid and other emergency stuff (including water) there.
    Personally, I'm not so sure how useful it would be for carrying the 110V charger around. That charger charges so slowly that it seems useful mostly (perhaps "only") for overnight charging. (Charging overnight slowly isn't necessarily a bad thing.) I can't really see myself using the 110V cable in any sort of emergency situation, say, nor draping it over from a motel wall outlet to my car, perhaps risking people tripping on it, etc. More likely, I'd strictly use it at home, and, on a trip, if I can't find a dedicated charger at or close to my hotel, I'd just (sigh...) use gas.
    Actually, I've already installed a level-2 charger at home (even though my P.Prime hasn't arrived yet!), so I probably won't use the 110V charger much at home either. I did so because I concluded that I don't have any 110V outlets in the garage vicinity that have the nominally-required 15A unused. Also, that'll let me top off quickly after work for evening errands, etc.
    iPhone ? Pro
    #36 mr88cet, Mar 15, 2017
    YPizza likes this.
  17. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    Going back to the original question...the extra length in the back has meant I have had to readjust how I park in a parking space. My last car was a gen 2, which I had for nine years. For the first month or so with the Prime, I would pull into a space at work and if there was not a car in front of me, I'd pull all the way through (I hate backing out), and 2 out of 3 times I would have to get back in the car after I parked and pull up further because the back end was in the space behind me.
  18. mr88cet
    2,313
    1,335
    Austin, TX
    That, as opposed to backing into the parking space?
    In my current Gen-2, I'm mostly used to backing into my garage now, so that, when my P.Prime finally arrives, I'll be able to quickly habitually plug it in. I'm not comfortable with backing in next to other cars yet though.
    For charging at work, if I can't use the back-in park assistance feature, I'll probably mostly back into charger spots that have a car on at most one side.
    However, the fact that my P.Prime will have the ultrasonic clearance sensors might help. Perhaps eventually I'll get comfortable enough with it to back in myself between two cars!
    iPhone ? Pro
  19. bisco
    52,756
    with that extended bumper, i'd probably be backing into a lot of things.
  20. mr88cet
    2,313
    1,335
    Austin, TX
    Which trim level? I've think I recall that the Advanced model's Intelligent Clearance Sensors make that hard to do. The back-up camera presumably would help too.
    iPhone ? Pro
