extreme newby driving questions
Discussion in 'Prius v Main Forum' started by lisalys, Dec 7, 2012.
  1. lisalys
    lisalys Junior Member
    16
    SF Bay Area
    So I test drove the v yesterday, and I am going back this morning to pick it up. I couldn't take it on the freeway because of traffic, but I did notice that it was hard to get up to speed on an overpass. Do you just need to floor it more? Admittedly my current car doesn't have a ton of power, but I can always throw it into 3rd if I need to. I'm all for getting great mileage, but I also don't want to get creamed by somebody because I can't accelerate on an on-ramp.
    I like the car, but I get the feeling it's going to take me a while to learn how to drive efficiently. The guy they sent with me was tossing out confusing information and flipping through screens, and I was still trying to figure out where the front end of the car was. :eek: I've been reading through all the driving threads, and it sounds like I should just keep it in pwr until I get used to it, but the videos I've seen have a horizontal bar instead of the vertical one in the v, so I'm not even sure where the electric cuts out and the gas cuts in.
    I get the feeling I'm going to be reading the manual end to end this weekend, but I totally want a 'driving the prius v for dummies' book.
    - lisa
  2. jayhawksrule
    jayhawksrule Junior Member
    Kansas
    I have had my Prius v for a couple of months now and I have found that it has plenty of power to get on the highway. If you put it in power mode it will surprise you with the amount of pick up, but I don't even feel the need to do that very often. I might use power mode if the on ramp goes uphill, or if its particularly short, otherwise normal mode works fine for me.
  3. lisalys
    16
    SF Bay Area
    jayhawksrule, that's good to know! The guy kept putting it in eco mode, which is probably why it felt like I couldn't get anywhere. :) But hey, at least I'm getting my buyers remorse and panic out of the way before I actually pay for it. :)
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    The eco mode reduces the sensitivity of the gas peddle. So when you need to accelerate you will have to push on the gas peddle a litttle more agressive or keep the Eco mode off. I went from a BMW with plenty of accleration to a Prius my first hybrid. It took awhile for me to adopt to the Prius about a week or so, but I'm satisfied with the car. The Prius can keep up with traffic and acclerate when needed. Grant it it will never have the power of a BMW but the car delivers other benefits for example unpresented Mileage, Cleaner Tail Pipe emissions, Reliability, room, comfort, and unpresented information at your finger tips and good smart phone integration. The car is a joy to drive but it is an aquired taste. The kicker for me is my gasoline bill went from above $300 per month to $80-120 per month with the Prius. Thats avings went into my travel and entertainmnet budget. My Bimmer was also starting to cost me for maintennace and repairs, the Prius gets 2 years Toyota paid maintennace and after that everying is reasonable. Probaly a little off topic but hang in theer you will enjoy the car more every day.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    Ditto above. You can set it to "Eco" mode and forget it. Just push the petal to the metal if you need it. Sometimes it will chirp the tires.
    PLSPUSH and JMD like this.
  6. lisalys
    16
    SF Bay Area
    rjparker, I don't know what 'chirping' is, but I have been slamming on the gas since I got it (about 45 minutes ago!). It's very disconcerting to see the mpg drop down to 15 while I'm going up a hill, but the 99.9 I got while breaking was a nice contrast! :)
  7. rjparker
    11,125
    6,980
    Texas Hill Country
    Chirping is "burning rubber" in a very limited Prii like way. The traction control feature prevents serious "smoke" from the tires. The point is it has enough power at times to force one of your many in-car computers to back the power down.
    I prefer the Trip B average mpg reading instead of the instantaneous readout that really does not mean much. Press the "Display" key and get "Average MPG" on the display instead of instantaneous mpg. There are actually three different average mpgs to use, one for the non-resetable odo (standard number of miles the car has run) and one each for the "Trip A" and "Trip B" counters. I like to reset my Trip B counter with every fill-up, which also resets the average mpg. Then you can watch the average mpg per tank.
    For realtime indications watch the vertical bar graph to the left side of the instrument displays. Whenever it shows EV you are on battery alone. Whenever the graph goes up past half way you are using a fair amount of gas. You are never using a lot of gas. That's the point of having one of these cars, besides it being a very good car in it's own right.
  8. rexg
    rexg Junior Member
    45
    San Fernando Valley
    ive also had the v for four days already and i have noticed that it is a little bit more sluggish than the gen ii even if it has a bigger ICE. (i think it is because of the added weight and size.) so it will never be as agile as the liftback counterpart. however i did not floor it since it had 1 mile when picked it up. now i have 160 so i am gradually increasing the power and noticed that it puts decent power to accelerate on the on-ramp. if this is your first prius, one thing i noticed after driving a prius for a few years is you will need learn how to feather the gas pedal in line with how the planetary gear reacts or else you will have a high revving ICE and it still gets you nowhere. :) After 4 days, I am slowly inching up to 40mpg. i am currently at 39.9 with a goal of getting 43 lifetime. my gen ii did 46.1 over the course of ownership up to 94k miles.
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    While not specific to the v, so far as I know John does not own a v, this is a short introductory manual to ease you onto Prius hood.
    John's Stuff - Toyota Prius User-Guide
    I have had my v for 4 months, it is peppier than my Gen 2 and THAT was peppier than the other cars I have owned, but I owned two Mazda GLCs, which is a really low bar, 59 HP.
  10. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Despite its so called sluggishness I've managed to "chirp" the tires on my v a couple times this past summer on bone dry pavement. Traction control isn't just for snow.:D
    Don't be afraid to stomp on it when you need to(though I suggest waiting till past your break in period before any full throttle acceleration or sustained high speed cruising).
    Doesn't matter if you are in eco mode or power mode, when you push the pedal all way down you will get maximum available power to the wheels.
    Just my experience, YMMV.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    Power mode is not more powerful. This is a common misconception. Full power is always available in all modes, including ECO. If you need more power, just press harder on the gas pedal.
    Most normal cars map a lot of engine power to the first bit of accelerator pedal travel. They do this to make the car feel more powerful and responsive. With the Prius, power is mapped in a fairly linear fashion, so you may need to press harder. ECO and Power modes change the mapping. Power makes it feel more responsive, while ECO does the opposite. It's just a matter of feel, as full power is always available.
    Tom
  12. jayhawksrule
    Kansas
    Yes, I know all that. It's more convenient to use than mashing the pedal to the floor.
  13. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Wow. Having people who accelerate on the on ramp would be quite the treat. Here in Washington state, most people speed up to 45 mph and then maintain it while they try to merge with 65-70 mph traffic. I'm usually at highway speed or greater (60 mph+) by the end of the ramp without any problems. I'm not even pushing the gas pedal to the floor to do so. Of course, then I have to it the brakes because everyone in front is going 45 mph!!! Sorry. I just had to vent.
    So, yes it has plenty of power to merge.
  14. Aptos Driver
    Aptos Driver Junior Member
    24
    Monterey Bay area
    We don't have a "v" yet, but we do have a 2012 Camry LXE hybrid. We leave it in eco mode just about all of the time and are averaging nearly 41 mpg after about 6,000-plus miles. I've found there's always plenty of power for accelerating onto freeways and climbing grades in this mode. I've also found that the eco mode increases the resistance of the gas pedal, whereas the accelerator is much more compliant in power mode. But what else does the eco mode do beside changing the pedal pressure?
  15. Aptos Driver
    24
    Monterey Bay area
    Move to California. Drivers here will tailgate you down onramps at 65 mph!
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It 'relaxes' the HVAC rules allowing more temp difference before starting the A/C.
  17. Aptos Driver
    24
    Monterey Bay area
    So if you're not using the A/C, aside from the gas pedal pushing back, it doesn't make much difference one way or the other?
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Correct. In Power mode early pedal travel has most effect, in Eco the most effect is near the floor, and Normally it has linear pedal activity. All three modes hit the floor with the same power, and idle with the same power, it is the middle that differs.
