Extreme vacuum in coolant system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ttou68, Jul 17, 2023.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,092
    Columbia, SC
    I'm hoping it will be flavored with some oil and carbon, maybe just a hint of glycol for freshness....
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Oh man… I pity the tongue!
  3. ttou68
    ttou68 Active Member
    351
    211
  4. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    I'm guessing your getting the cold start missfire on startup, if so try unscrewing header tank cap when you park up for the day.... If it starts next day without missfire it's looking like gasket..... Had 2 do this and neither showed oil in water or water in oil... But both blow gaskets.
  5. ttou68
    351
    211
    I bought it broke down, drove it onto tow dolly and tow it home. It never misfire the 2 times I started it..
    I bought it without looking under the hood; I was not able to open it to check because it was frozen in ice, and I just assuming it need it head gasket replacement based on the codes I scanned..
    I took engine apart today after boroscope it, and found number 2 cylinder was compromised...
    So, head gasket job. Just what I suspected...
    #25 ttou68, Jul 20, 2023
    Mendel Leisk and jzchen like this.
  6. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    If there was little coolant left in the system, I think you'll need more than a head gasket. Consider another engine, used or rebuilt.
    iPhone ? Pro
  7. ttou68
    351
    211
    Possible...
    So, far no bent piston rod, everything else loosks okay..
    Will check cylinder head when I make it back in town tomorrow morning...
