Eye surgery
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Feb 23, 2026.
  1. bwilson4web
    16,527
    • cataract surgery 9:30 AM , now 4:40 PM
    • Laser variant breaks up the old lense
      • Pretty light ahow
    • Very quick procedure, less than 10 min
    • About an hour prep:
      • Chill the patient to the verge of shivering (thermal underwear advised)
      • Bring homemade medical card so you won’t have to mispronounce meds with too many consulates and the same old, boring questions.
      • Modern pain control is awesome!!!
    Wish they’d given me a Pirate’s eye patch. When is speak like a Pirate day? AARRGG.
    futurist, mingc and bisco like this.
  2. hill
    9,026
    Looking great! You'll be shooting in no time
  3. ChapmanF
    19,002
    Is the chilling the patient a part of the procedure? And, if so, would thermal underwear just make it take longer?
  4. Winston Smith
    Winston Smith Active Member
    460
    332
    OH
    2024 Prius
    LE AWD-e
    • I just had my second eye done a couple of months ago, but with a blade.
    Do you have a weight limit for the next month? Do you need to apply drops to your eye four times a day?
    I'm not complaining; my result was good both times, but I the prohibitions on picking things up for a month were irksome.
    I'd be curious about your lens choice, if that's anything you'd want to write about.
    #4 Winston Smith, Feb 23, 2026
  5. ETC(SS)
    7,529
    Right eye dominant?
  6. bisco
    52,820
    I’ve had both eyes done. Then they developed some kind of coating or scarring or something, I forget exactly.
    But they blast that off with a yag laser and everything has been great since.
    All the best Bob!
  7. bwilson4web
    16,527
    I wanted to share what I’ve learned to show how much better practices have become.
    As for me:
    • Right eye dominant - I recently fired 30 rounds all hits, iron sights, into a feral hog target at 200 yards with more than half in the heart-lung center.
    • Crescent moon motivation - I notice two crescent moon images as if they were spooning. At the next charging station and no window glass, the right eye saw two sharp spooning images. The left had three larger less distinct and a smear between the two.
    I had a cataracts diagnosis for the past four years but not enough to require treatment. But the spooning moons was new.
    So if this thread does any good it will reduce trepidation about cataracts treatment. Hopefully share my threshold symptoms.
    #7 bwilson4web, Feb 23, 2026
  8. Winston Smith
    460
    332
    OH
    2024 Prius
    LE AWD-e
    This was an effect of your astigmatism?
    My primary complaint was a cloudiness that made looking toward light untenable, but I mentioned seeing a couple of ghost images a few degrees apart and was told it was because of the kind of cataract I had. That eye has a pronounced astigmatism as well.
    I won't pepper you with more questions. I do find the process interesting, and know from the experiences of my older partners that people have all sorts of different experiences with it.
  9. ETC(SS)
    7,529
    Like some 20% of the population, I'm cross eye dominant.
    Since I did not identify and mitigate that early on, I will always be a very marginal rifleman.
    I did qualify Expert for both in the USN but only a few times late in my career for the rifle.
    For pistol shooting I adjusted much more easily, and now with red dots I get to 'shoot younger' for a little while longer. :)
  10. Winston Smith
    460
    332
    OH
    2024 Prius
    LE AWD-e
    Red dots were my tell.
    Three red dots on a target might be great for The Predator, but I didn't care for it.
  11. ETC(SS)
    7,529
    I think we're talking about a different red dot....
    fuzzy1 likes this.
  12. Merkey
    Merkey Active Member
    329
    302
    Birmingham, Michigan
    Post surgery laser use is for posterior capsule opacification. I got multifocal lenses 10 years ago but did not need the PCO laser procedure. Cataract surgery was money well spent.
    bisco and Winston Smith like this.
  13. bwilson4web
    16,527
    Diagnosis was confirmed when I glanced at the crescent moon and saw:
    • right eye - dominant, two crescent moons
    • left eye - slightly larger moons with a faint could between them
    None of optometrists instruments showed me this effect. Had I seen it before, I probably would have had the surgery years ago.
  14. fuzzy1
    10,698
    My eyes have started doing that too, in the past few months (since the most recent optometrist exam), most noticeable during night driving when the pupils are open wide. My offsets are vertical (not diagonal), and disappear when squinting or in brighter light where the pupils naturally contract, using less of the lenses.
    I've been suspecting this is related somehow to astigmatism, which has been present since childhood but has become my primary correction, as the youthful strong near-sightedness has shifted with age to weak far-sightedness. Astigmatism alone doesn't do this, some additional lens warpage must be developing.
    futurist likes this.
  15. bisco
    52,820
    Mine were just getting blurry
  16. futurist
    futurist Member
    57
    179
    United States
    2024 Prius
    Yup, astigmatism. Have a few degenerative eye problems, and that is one of the tells -- the vertical offset of sources of light at night. Mine are diagonal (oblique astigmatism), yours are with-the-rule astigmatism.
  17. bwilson4web
    16,527
    The problem is uncorrected distance vision along with near-by reading glasses needed. So this is my latest experiment:
    • Perfect distance vision above the lenses
    • Perfect Tesla screen vision through the lenses
    futurist and bisco like this.
  18. BiomedO1
    BiomedO1 Senior Member
    4,568
    2,398
    Left Coast
    Just a word of caution; If you opt for cataract - lens replacement - DO NOT allow them to do both eyes at once. Same with laser surgery. They tried to pull that one with my mom and I insisted one eye at a time. If the equipment is out of specs or slightly misaligned - they would mess up both eyes, if they were doing both of them at once. Your also going to be BLIND for a bit while they heal. If they're done one at a time - you can at least have some mobility/functionality. I don't know what that ophthalmologist was thinking. The HMO was hesitant at first, claiming that all the documents has been signed. I told them that paperwork better NOT be in English, because her English isn't that good. When I told them where I worked; they quickly backed down and did one eye at a time, about a month apart.
    Just something to think about.....
    futurist and Winston Smith like this.
  19. tochatihu
    tochatihu Senior Member
    9,970
    3,847
    Kunming Yunnan China
    2001 Prius
    @fuzzy1 name here is finally explained. :confused:
  20. bisco
    52,820
    did ben Franklin invent those?
    Merkey likes this.
