Fabric / Cloth Seats and Lower Back Pain
Discussion in 'Gen 3 Prius Accessories and Modifications' started by zyx345, Aug 16, 2011.
  1. zyx345
    zyx345 Junior Member
    42
    Northern, NJ
    I just purchased a Prius Three (III) and I'm really happy with everything on the car however I am experiencing some lower back pain with the fabric seats.
    My prior car was an Acura with Leather seats and lumbar support.
    Prior to my purchase I rented a Prius II from Hertz for 3 days and did not experience any lower back pains after about 100 miles of driving. I also test drove a Prius IV for about 20 minutes and also did not experience any lower back pains.
    I did some Google searches as well as searches on this forum and it seems that most suggest adding a Lumbar Cushion.
    Has anyone done this with success? If so, any recommended brands/models?
  2. donee
    donee New Member
    2,956
    194
    Chicagoland
    Hi z...,
    I had this problem, and resolved it with a seat pad. The issue was the lumbar support , although there, is too high for me, when my weight compressed the seat pan cushions. So, I made some cushions from high density foam for the seat pan. This lifted me up, aligning my lumbar region with the seats lumbar support.
  3. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    I have had chronic lower back pain fo 40 years. I have used a lumbar pillow in my cars and trucks for many years to relieve the pain. The kind with memory foam seem to work the best.
    Try it.
  4. ursle
    ursle Gas miser
    1,049
    189
    NH
    +1, can't sit for ten minutes without it, often sit for 12 hours with it.
    Duro-Med Lumbar Cushion with Strap, Navy, 14 x 13
  5. Skoorbmax
    Skoorbmax Senior Member
    2,641
    263
    Western NY
    Has the worst support in any car I've had in years (Prius II). My last trip of 90 minutes (is an absolute eternity in that seat without some extra support) I just folded up a towel and it worked great.
    One of the great frustrations of my life is chairs made without even an inkling of consideration for proper spine alignment.
  6. MikeR5
    MikeR5 New Member
    185
    Sherman Oaks
    Ut oh- I am planning on buying a II in the next week or 2. Maybe I need to rent one and do a long trip? I have had back problems in the past.
  7. zyx345
    42
    Northern, NJ
  8. zyx345
    42
    Northern, NJ
    If you rent one, I'd recommend doing at least a 90 minute trip with it straight to give you an idea of how the seats are. I rented one but did a bunch of short trips at about 30 minutes each and did not experience any back pain.
    I think its the longer trips that get uncomfortable. The car is awsome otherwise.
  9. xs650
    xs650 Senior Member
    4,539
    1,424
    Northern California
    A rental is a good idea:cool: but it can take at least 3 hours for discomfort to show up.
  10. MikeR5
    MikeR5 New Member
    185
    Sherman Oaks
    Well- I think I'm buying and hoping for the best. My Gf has a Rav 4 and I have had no back problems- anyone know how those seats compare?
  11. donnaj56
    donnaj56 New Member
    Kentucky
    I had the same problem when we first got our Prius and I know this sounds too simple and it will not work for everyone but I leaned my seat back just one stop farther than I would usually keep it. I haven't had a problem since.
  12. zyx345
    42
    Northern, NJ
  13. zyx345
    42
    Northern, NJ
    Actually this has helped tremendously. Thanks! Still not perfect but appears to be the best I can get it.
  14. ursle
    ursle Gas miser
    1,049
    189
    NH
    The lack of straps is good, kiss "keep it simple stupid", just don't sit on it when you get in, then adjust it exactly where you want it once you're in and it stays.
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    150
    +1 to zyx345's comment. i have one of those cheap stretchy mesh lumbar supports.. super cheap... and works wonderfully... it feels like it's not there most of the time.. i rest my elbow on the edge of it at times.. i really really like them.
  16. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    I've a set of Clazzios waiting to be installed... but plan first to get a professional auto upholstery shop to fit a memory foam lumbar support under the standard fabric... and then install seat heaters between the fabric and the Clazzios.
    I tried the Wal-Mart air thing... worked pretty well, but wouldn't want it under the Clazzios, with the heaters, etc.
  17. ChaiLove
    ChaiLove Junior Member
    32
    Virginia Beach, VA
    I have major back problems which I was born with. My last car was very uncomfortable and I did have to use a lumbar support in it. I have found that by adjusting the tilt of the seat I have no problems with back pain in my Prius.
  18. eroeder
    eroeder Junior Member
    72
    22
    Dallas
    2018 Prius Prime
    I will have to try the tilt further back too. I LOVE the car, but could not understand why my sciatic nerve hurt after long drives, causing me to limp for about 20 seconds until the blood flow started again. I bought a memory foam lumbar support and it has really helped, but it doesn't stay put and always has to be positioned.
    Man, I thought it was just me....
  19. priusrick
    priusrick Member
    257
    37
    I bought one of those Medi supports but it doesn't fit real well between my back and the seat, maybe I need to do the custom install under the cloth. hmmmm./.....
  20. Den49
    Den49 Member
    498
    265
    Maryland
    One of the reasons I bought the IV was because it was the first level that had a seat with an adjustable lumbar support.
    The seats were comfortable for two years, but after two years of wear, I had to augment the seat cushions by removing the seats and inserting one inch upholstery foam between the springs and existing foam. This restored the cushioning and made them comfortable again. Toyota seats in general are not as good as they once were.
Loading...
