Factory Aux console plug to aftermarket stereo
Discussion in 'Gen 3 Prius Audio and Electronics' started by Ajwatuc, Jun 12, 2013.
  1. Ajwatuc
    Ajwatuc Junior Member
    75
    Anyone done this im wondering if there is a plug and play option or would i have to splice the wires to a 3.5mm jack
  2. FriarNurgle
    FriarNurgle Member
    138
    53
    Save up a bit more and get a better aftermarket stereo with proper USB aux input.
  3. ursle
    ursle Gas miser
    1,049
    192
    NH
    I can't read the op's post because the advertising on the page is covering part of it, just sayin
    Seems you have to get the sheep to read the material before they are going to buy the farm;) just sayin
  4. FriarNurgle
    FriarNurgle Member
    138
    53
    Try using Ad Blocker.
  5. Ajwatuc
    75
    I have a usb on my head unit too, but lets stick to the question.
  6. TenCrawler
    TenCrawler Junior Member
    17
    Anyone? I'm going to finish my install this weekend, and I was hoping to do it all at once, but it seems no one has an answer for how this connection works. I will update with what I find out. I am going to use the rear expansion port on my new HU for the console AUX input, and they have two available add-on adapters to choose from; an RCA or 3.5mm Male. I want to see which will allow for the most "seamless" install.
  7. FrankB
    FrankB Member
    117
    53
    I can't post links but do a google search for "Adding a free Aux in to a 2007 Prius" and it has the pinout for the AUX connector. You should be able to ignore the Aux Sense (pin 19) and wire up the Audio signals (pin 15, 16 and 17).
    Frank
  8. TenCrawler
    17
    Perfect. I think the 3.5mm adapter will be easier to splice than the RCA (3 wires vs 4 wires). Thanks for the help.
