factory plugs 2010 and death rattle
Discussion in 'Gen 3 Prius Technical Discussion' started by Tombukt2, Sep 27, 2023.
  1. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    Anything going on with this My other half was telling me that she read somewhere online I don't want to say it was here that someone put in the wrong spark plugs in a generation 3 and it caused the death rattle than they changed to the factory double iridium or some such nonsense? I haven't heard anything about this Is this even a thing? I think I have what SKS 20R11s in mine and believe that number comes to mind I don't know the four digit stock number.
  2. Higgins909
    Higgins909 Member
    289
    71
    I'm not sure about car engines but with my 2 stroke lawn stuff, the wrong plug will can make it run worse and better at the same time.
  3. Tombukt2
    13,879
    2,521
    Durham NC
    The dealer is telling me for my 2010 2Z FXE I'm supposed to have SC1611s I believe that's right I called the dealer I was thinking it was SX16 I was also considering the twin tip or the TT Nippon denzo plugs which I have I think in a 1z but not the two Z.
  4. Mendel Leisk
    42,382
    Close, the the (current) stock plug is Denso SC16HR11. Owner's Manual says Denso SC20HR11. The SC16HR11 is slightly hotter, guess Toyota decided there was a bit too much deposits happening, so revised the plug.
    I got some last fall through a dealership (surprisingly the best price local to me), and the box had a Toyota part number: 90919-01275. It's the Denso plug inside though.
  5. Mpdcnva
    Mpdcnva Member
    51
    27
    Washington dc
    Four Touring
    If you have a death rattle. Remove the antifreeze cap o ring and drive for a couple days. If your death rattle stops. You need a head gasket. Simple test.
