Faint clunking noise coming from 07 Prius when not moving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shumiron, Feb 7, 2023.
  1. shumiron
    shumiron Junior Member
    When I am in the car parked with the car off I can hear a repeating faint clunking sound that lasts for a few seconds then repeats at intervals of a couple minutes or so. This goes on constantly and does not matter if the key is with me or not. I just replaced the inverter coolant pump and all seems good with the car.
    Car info - Base model without keyless entry
    - 211,000 miles
    - Runs excellent but low MPG. less than 40 MPG
    Tombukt2 likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    I had a front caliper not releasing causing loss of about 4 mpg.
  3. Tombukt2
    13,845
    2,515
    Durham NC
    Check you're rear brakes no leaks etc.
    52,819
    is it under the hood?
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Could this be the brake accumulator going out?
    What does the 12v battery measure at the jump points under the hood?
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    If the sound seems to come from under the rear of the car, that might be the leak detection pump running a test on the EVAPorative emissions system.
  7. shumiron
    Hello everyone. I have listened more carefully and I believe the noise is coming from the High Voltage battery area. I did a 12 V battery check on the display panel and it reads 11.6 volts with car in accessory mode and 14.1 V when Ready.
  8. bisco
    52,819
    that's a bit low
