Faint, high-pitched whine when coasting...
Discussion in 'Gen 3 Prius Main Forum' started by Vege-Taco, May 1, 2012.
  1. Vege-Taco
    Vege-Taco Junior Member
    78
    Arizona
    Has anyone else noticed the barely audible (with good ears) high-pitched sound that emanates from the car when you let off the throttle enough to prevent any charge or discharge bar from showing? It goes away if you completely release the throttle or if you press the throttle a tad bit more.
  2. BOS-KC1
    BOS-KC1 New Member
    Boston
    I noticed similar faint high-pitch sound when I have my radio on, possible interference?
  3. RaZa
    RaZa Member
    480
    93
    probably the vpns (vehicle proximity notification system) aka the "noisemaker"
  4. Vege-Taco
    78
    Arizona
    It's a completely different type of sound. It sounds like an electrical noise, not like a speaker. I know what the noisemaker sounds like, and it's a much lower pitch sound as well as warbley.
  5. Vege-Taco
    78
    Arizona
    I'll test out this possibility. I usually do have my radio on...
  6. schorert
    schorert Member
    127
    51
    mass
    are you married? check the passenger seat.
  7. markabele
    5,084
    1,782
    Nebraska
    I notice it sometimes too during battery regen. I actually kinda like it. I feels more high tech.
  8. Tandem Rider
    Tandem Rider Junior Member
    56
    Indianapolis, Indiana
    I have noticed a high pitched whine when the EV is on. My 89 yr. old mother has great hearing and she mentioned it today when going to the store.
  9. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    the electric motor is not completely silent. my old '04 'whines' when slowing and that is the regen on the big electric motor. then at slow speed (EV, no gas engine), a "quiet" whine is audible up to say 30 MPH when the air and road noise drown out the electric motor.
  10. El Dobro
    El Dobro A Member
    7,102
    3,280
    I thought it was the inverter during a regen. When I'm lurking through a parking lot, there's no noise.
  11. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I've noticed a really high pitched sound similar to tinnitus that I didn't have or at least noticed on my 2011.
    It happens most of the time on battery even when I am stopped. A higher pitched and louder than I remember with my 2011.
    If I tap the brake sometimes it will stop the sound.
    I noticed it right away when I bought the car going from 11 to 12 Prius.
    I unplugged the noisemaker so it is not that.
  12. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Also forgot to add my friend noticed it too. I unplugged the noisemaker and when i drove off slowly with only battery he was outside and mentioned what I high pitched sound that was coming from the car.
    He never noticed it with my 11 Prius.
    Anybody have any idea?
  13. El Dobro
    El Dobro A Member
    7,102
    3,280
    Mine sorta sounds like this.
  14. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Mother in-law in the back storage area?
  15. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    lol - mine use to before I unplugged the noisemaker.
  16. Vege-Taco
    78
    Arizona
    Again, it is not the noisemaker sound. It is a much higher pitched sound and is not nearly as loud.
  17. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The electric motors and associated electronics (inverter) make a high pitched sound. This comes from the high frequency electrical pulses used to drive the motors. Speed, loading, and environmental factors will influence the sound, so sometimes it is more obvious than others.
    Tom
  18. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Beside an earlier post by Raza, no one is saying it is the noisemaker.
  19. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I've noticed it too- It's a rather high pitched whine, in older cars it used to be called alternator whine and you heard it over the radio. Must be related to the regen/inverter system on the Prius...
  20. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    Yes, it's the inverter.
    If I had to peg it down to a specific component inside the inverter, I might guess that it could be some inductors, but I don't really have any basis for that. I just know that I've heard inductors in consumer electronics before - I had a laptop where I could hear when the CPU was not under heavy load, because it made the inductor vibrate in an audible frequency range. Turning off one of the power-saving features would keep it out of that range. Then, in my job once, I worked for a few weeks with somebody who was quantifying how much inductors on a circuit board move, and how they wobble, and a bunch of other things, in an attempt to reduce or eliminate this noise.
