Fair purchase price for used 2012 plug-in advanced w/17.5K miles in CA
Discussion in 'Dealers & Pricing' started by Loran, Sep 3, 2013.
  1. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    What kind of gas mileage do you get in your 2011 Prius? I bet its more than 44MPG. Point is, their testing of the Prius (hatchback, Plug-In, C, V, all of them) seems to be questionable.
    There are many threads in the News subforum that discuss Consumer Reports and their testing methodology. If you think they are professional and unbiased, I encourage you to read those threads.
    In fact, here's a thread discussing the EPA's comments about Consumer Reports poor test results:
    EPA to Consumer reports - "your tests are awful" - hybrids do better than you test | PriusChat
    fortytwok likes this.
  3. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    I don't get a trim option on that page. I've tried it in Firefox and IE 9.
    What browser are you using? I'd ask for a screenshot but that's probably more trouble than most would go through.
  4. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    In response to tplife, post: 1878087, member: 117291, "From Consumer Reports...."
    I am a supporter of and subscriber to Consumer Reports. CU is especially useful when I have not done independent "homework" or do not have independent experience needed to make my own judgements. CU testers do not drive like I do. They got 44 mpg average with a standard Prius. The six year lifetime actual average mpg of my 2006 Prius was 49.36. CU puts greater value on price and a plush interior than I do. I value dependability and the solid reputation of Toyota enough to over ride these factors.
    There is plenty of information available on this board to affirm that the Prius generally and the PIP specifically, is/are a dependably remarkable car. My personal hands on experience over the past 16 months with this car fully supports that.
    Ideally, everyone should make an informed choice based on exhaustive study and knowledge compared to their dearly held habits and values.
    Absent that, the best we can do is pick up bits and pieces here and there and do what we can.
    One who makes a choice which satisfies is a winner.
  5. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    pure rubbish and that article has been roasted before
    I live in a really hilly area and only once in 5 months has the gas engine kicked in going up a hill. Even in that instance I'm wondering if that was due to using no gas for 125 miles.
    3.5 hour charge ? if they're unbiased where's that coming from ? I've been getting a full charge in 70 minutes on a 240v and under 2 hrs at home through that common household outlet.
    Lourun likes this.
  6. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    Using Firefox on Windows. But I just did it again on Safari on my Mac, and indeed, the Trim menu is not there! Wth?!
  7. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Modify Search -> Year range -> 2012-2014
    Modify Search -> Keywords -> Plug-in
    How much is he asking?
  8. tplife
    tplife Junior Member
    85
    24
    SoCal
    If you read the article you know CR recommended the Prius as a dependable, reliable car, just not worth the premium vs. the regular Prius hybrid in their assessment. You are free to disregard their findings, and buy whatever floats your boat! AFA charging time, CR is likely basing the charging time on 110V with their own particular line-in, which varies depending on where you live - it's so bad where I live I use conditioners to eliminate noise on my high-end audio equipment. Consumer Reports uses a standard test track at their facility for every vehicle they test to get accurate measurements and comparisons - in my field of science we call this the "scientific method". They test every vehicle in the same manner under the same conditions on the same track, otherwise their data would be contaminated. I am familiar with their techniques as a science professional and find them to be the most accurate out there. There are reasons why their opinions are trusted as unbiased. Your mileage may vary because you don't use their track for comparison purposes...If you trust the EPA (biased depending on which way the wind blows and what the "boss" tells them to say) over Consumers Union, well then, my friend, you're on your own! :ROFLMAO:
    “At first, they'll only dislike what you say, but the more correct you start sounding the more they'll dislike you.”
    Criss Jami
  9. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I did read the article and it was poor reporting. Our family actually subscribed for years so this was disappointing.
    Usually I'd take their findings as gospel but here was a case where I actually owned the product being reviewed...
    For one - a big one - it came out late enough for them to know that there is no "premium vs the regular hybrid" to speak of. My net after taxback is 24k and probably even lower as I was conservative with assumptions on the 0% 60 mo financing and some would say I'm paying less than for the similar Prius 3.
    I understand the test track and all but you'd have to have a real lead foot to get the results they're showing.
    Yes they could drive the comparable non-PiP's in that same way but what about those of us who don't drive any vehicle in that manner? I'm guessing someone considering and buying such would be a bit interested in maxing MPG...
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    When I traded in my 2012 PIP Advanced with 20k miles on it the dealer put a $34k sticker in the window. That was in NorCal in July. The dealer were offering less on average in SoCal so my car probably would have been priced lower.
  11. drash
    drash Senior Member
    2,574
    1,313
    Upstate NY
    I'd have to agree 100% with this. When I take trips longer than my typical 4 to 7 mile jaunts, I usually see these results as well with using HV on the way out and draining EV on the way back. As a side note when I use the PWR button with the HV on the way out, EV boost is twice as long as normal or ECO during cold starts.
  12. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    If you believe this article as the gospel, good dont buy a PIP, there will be one more for the people that believe the masses instead of magazine testers that have proven they don't know how to drive a hybrid.
    fortytwok and rogerv like this.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Then there are those of us who sort of agree with the article and switched. :p
    In reality, for a lot of people the PIP can be extremely efficient.
  14. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Then I guess I have a bridge in Brooklyn I could sell you!
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No thanks. I got rid of my antiquated rattle machine why would I want another? :p
  16. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    3 new cars since 2012 ? !
    why not trade in that Volt for a Tesla
    Lourun likes this.
  17. bisco
    51,757
    this thread has more twists than a twizzler. i wonder if the op got lost?:cool:
  18. tplife
    85
    24
    SoCal
    CU is averaging the mileage out vs. standard Prius models vs. Chevy Volt vs. Tesla vs. GMC Sierra vs. whatever on their particular track. Their data is for comparison purposes. Calling it "poor reporting" is meaningless as each state takes taxpayer's money and redistributes it differently regarding Hybrid models, and each taxpayer in that state pays for it in "the end". Taking 0% interest rates into consideration regarding out-the-door cost? Please, tell me you're not doing anyone's finances other than your own (Most of us paid 0% for our loans if we could anyway). And then tell me you paid CU to find out what the "dealer's cost" net/net/net was and then paid less than that - I did, and you did too, right? CU knows about the state rebates like everyone else, and found that while attractive, reliable, and recommended, this particular PIP is not cost-effective ITO for typical hybrid buyers vs. the standard model. No one is going to sink the money for the PIP and then switch back because "some scientists" said they should. They're going to convince themselves they got a good deal and be happy with it. Isn't that what makes America great? :)
  19. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I'll keep it simple -
    1- I didn't mention or factor in state rebates. Pretty easy to calculate a $2500 fed back and whether they are taking a dime from other taxpayers to get me my $2500 isn't material to my finances.
    2- re 0% financing - are you serious that you wouldn't place a value on such ? since this is in context of paying a "premium" over the Prius3 it should be simple enough for a scientist to calculate...
    Same dealer, same time had 3% financing on the other models.
    re Sinking $ into the PiP -
    Read again : I paid $1,000 more for a PiP than a Prius3. Do some homework and you'll see prices in the 27s for base PiPs - its not 30k and hasn't been for quite some time.
    I could've paid cash and missed out on earnings on that cash, paid Toyota 3% interest on a P3, OR paid no interest for 60 mos on a PiP...
    I've driven almost 6,000 miles now on 10 gallons.
    A P3 would've given me what 1/10 that at best ? (unless I drove it like Consumer Reporters)
    Looks like that big premium will be gone inside of a year.
    Its been pointed on the roasting of that CReports review but I'll mention it again - IF we chose to drive a PiP like a racecar then the advantages decline. And that's where common sense and scientists part ways.
    They may as well have reviewed a hammer poorly because it fails as a screwdriver
    rogerv and Lourun like this.
  20. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Boy do I agree with you 100%
