Fan icon near range display
Discussion in 'Gen 5 Prius Main Forum' started by JimLudden, Feb 9, 2024.
  1. JimLudden
    JimLudden Member
    Taos, NM
    2024 Prius Prime
    What does this fan icon mean? I cannot find it in the quite unhelpful documentation.
    It is located on the 'speedometer' (my old-fashioned term) just above the range values in the lower right.
    Looks like a fan. [Rats. Can't figure how to upload an image or link to it.]
  2. Zeromus
    Zeromus Active Member
    553
    309
    Ottawa Canada
    2024 Prius Prime
    SE
    When you turn on the fan, in EV mode it reduces your range.
    It just tells you "this is the EV range with fan/AC/heat system on" and when you turn off the fan, it adjusts the range up higher and the icon goes away.
    I think it's supposed to be helpful, especially in eco mode, because auto fan "eco" setting sometimes you don't even realize it's on its so quiet. So having an icon at the speedometer was probably decided on since alternatively you need to look down at the temp controls.
  3. JimLudden
    JimLudden Member
    Taos, NM
    2024 Prius Prime
    Thanks, Zeromus.
    So this is an indicator that the heat pump is running (using electricity from the traction battery). That makes sense.
    Too bad that the documentation does not show the icon and explain it, but glad that this forum is here.
  4. JimLudden
    JimLudden Member
    Taos, NM
    2024 Prius Prime
    Now that I have learned to turn off the Heat Pump (with fan icon) when my car sits in the sun (even in winter), the sound level inside the car is much lower! With heater going, the car was never 'silent', but I could still hear when the gas engine fired up.
  5. KMO
    KMO Senior Member
    2,026
    750
    Finland
    2023 Prius Prime
    In the "instrument cluster" section on p.159, we have:
    I'm with you on the heat pump. Far louder than the engine... I find the idea of "you don't even realize it's on its so quiet" rather comical. :ROFLMAO:
    Tideland Prius likes this.
