Fan noise when I turn off my Prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Phil Viana, Jul 23, 2017.
  1. Phil Viana
    Phil Viana New Member
    Austin, TX
    2015 Prius c
    Every time I drove for more than 5 minutes, when I get home and turn the car off I hear a weird, squeaking noise. I *think* it may be the cooling fan, but to be honest I had never heard a fan squeak like that. I recorded a video and uploaded it to youtube:
    It's a 2015 Prius C One. Do you guys hear a similar noise?
    52,885
    welcome!
    probably the coolant pump refilling the thermos.
    Phil Viana likes this.
  3. Phil Viana
    Austin, TX
    2015 Prius c
    Thanks for the reply! Is it common for this to happen 90% of the times I turn my Prius off?
    After owning the car for 2 years I wonder why I'd never heard the noise before, but I suppose it may be because of my new garage which is a lot more silent than my previous one.
    52,885
    the sound is unusual, so it may be that the pump is on it's way out, and also why you are hearing it.
    who knows, could go for years like that.
  5. Phil Viana
    Austin, TX
    2015 Prius c
    I found a similar video on YouTube and got in touch with the guy who posted it. He said he thought it was the AC.
    I drove for half an our with the AC off and when I turned the car off... No noise! Then I turned the car on again for five minutes, this time with the AC on. I heard the noise again when I turned the car off!
    So it's definitely the AC. I just don't know why or what exact part of it. Any thoughts?
  6. Javierz0509
    Javierz0509 Member
    112
    52
    Miami
    Mayby the ac needs freon?
  7. Phil Viana
    Austin, TX
    2015 Prius c
    Maybe. The AC is working perfectly, though. I can't see anything wrong with it. If it needed freon wouldn't my car be really hot? (I live in Texas btw)
  8. Phil Viana
    Austin, TX
    2015 Prius c
  9. Phil Viana
    Austin, TX
    2015 Prius c
    I took the car to my mechanic and he said the noise is perfectly normal. There is nothing to fix.
  10. bisco
    52,885
    excellent!(y)
  11. PrincePrius84
    PrincePrius84 Junior Member
    Dallas, Tx
    2017 Prius c
    I know what noise your hearing I think based on what I can roughly hear, I had/have a 13 Camry with 157,000mi and a 17 Prius c Two, as the Camry got older in mileage it started making that noise, like you I was concerned something was wrong, but I was told by teachers at my auto vocational school that it was nothing to be alarmed about an most of them have 20 to 30yrs experience in the field, btw I am in Texas too
  12. 08PriusXSJ
    08PriusXSJ Junior Member
    42
    Connecticut
    My Prius C2 (2012) has a high pinch noise with the sound like an electrical transformer in working whenever I turned the A/C on. The noise immediately stopped once the A/C was off. Also, the cooling fan will turn once the A/C is on and stops when the A/C is off.
    At the moment, I could not be for sure whether the noise is from the A/C compressor or from the cooling fan. I will take to my mechanics and let him tell me what the problem.
