Fan only, no Heating or Cooling
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by JoeRaber, May 10, 2013.
  1. JoeRaber
    JoeRaber Not my real name
    Utah
    I would like to be able to use the fan to bring in outside air with no heating or cooling. What I have been doing is turning the temp setting to Low and controlling the Fan Speed manually.
    This seems to work unless the outside temp is too low, then it seems to be heating the air a bit, which I don't work.
    Is there a different way of doing this? I feel like I am missing something.
    Thanks
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    That's the way it's done.
    I haven't experienced the heating that you have though.
  3. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Hey Joe,
    That's what I do as well. But, I haven't noticed any warm air. How low are the temperatures we are talking about?
    52,490
    ^ditto^
  5. JoeRaber
    Utah
    When the outside temp is in the 50s it seems like the air coming out the vents is warmer. Maybe it is just being heated as it passes through the system. This is not a big deal, I just wish they had kept a separate Vent setting.
    Thanks for the replies, I guess I am doing it the right way.
  6. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Maybe at colder outside temps the exhaust heat recoup system bleeds some heat to the cabin air system.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    If you set it on low it will cool the air. Theoretically, to attain no heating and no cooling, that you could feel, you would need to set the climate control temperature to the same as the inside air temperature, so you would need a separate thermometer inside the car.
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    This is incorrect. If you turn off the AC (press the button to turn its LED off) it will not cool the air.
  9. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Open a window or sun roof
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It will still try to cool the cabin by blowing more outside air in if the climate is set to auto temperature control and the outside air is cooler, but adjusting the blower speed manually will counteract this by dropping it out of auto.
  11. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I agree. The object of the OP was to do exactly that: bring in outside air without heating or cooling it.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Oh, without heating or cooling the incoming air, I thought he meant without heating or cooling the cabin ?:unsure:
