FastSkinz- have you heard of em? 18-20% mileage boost...
Discussion in 'Gen 3 Prius Fuel Economy' started by MrChristian, Jun 23, 2009.
  1. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    And the dimples on that ball makes it rotate in a controlled manner, creating extra lift by that article and the researcher. Too many rpms and it is detrimental:D
  2. dogfriend
    7,512
    1,191
    Carmichael, CA
    I was just thinking about this over the last couple of days: If this really worked, you could just buy some spray on texturing material (sold at Home Depot, et. al. for repairing textured sheetrock) and roughen up your Prius by spraying it on in a strategic manner. A cost saving tip for the frugal members of the forum. :madgrin:
  3. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Yes, if they don't mind the finished looks:D
  4. Argyle
    Argyle New Member
    87
    22
    Rochester, NY
    Whenever you use FastSkinz condoms, make sure you use plenty of Pulse & Glide brand lubricant. Ask for it by name.
  5. patsparks
    10,664
    569
    Adelaide South Australia
    Or just buy paint and spray it badly to create orange peal effect.
  6. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    The heading had me thinking maybe someone has already tried something I've been contemplating in my quest for LRR tires. That is, getting a strip of innertube, possibly from a bicycle tire, about an inch wide, and stretching it around the circumference of each of the tires. This would give a narrow and smooth point of contact with the road, thereby "increasing the mpg by 18-20%." I'm sure there would be safety concerns, but with my conservative driving style I think it would be fine. Any takers?
    PA P
  7. bwilson4web
    16,456
    Steel:
    Just mill out the center and turn them down to fit. Great rolling resistance and your glides will be something of wonder. Best of all, no 'sprung weight.' Besides, the 2010 has four-wheel, disk brakes.
  8. PA Prius
    762
    251
    SE Pennsylvania
    ... not to mention that great flywheel effect!
    PA P
  9. dogfriend
    7,512
    1,191
    Carmichael, CA
    I've always thought that the much-maligned space saver spare tire(s) could be a great fuel saving solution. Just mount four of them on the car in place of the original tires and wheels. The tires are rated for 60 psi (IIRC) and the max rated speed is 50 mph, so that will help with FE too. :madgrin:
  10. OZ132
    OZ132 Member
    170
    Northern Indiana
    Actually, snake oil might make the car more "slippery" thereby decreasing the coefficient of drag a bit--if you could keep it from blowing off...
  11. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Lots of lulz !
  12. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    Say wha'? I've been doin' it WRONG?!?!?
    ( snicker .... )
  13. dogfriend
    7,512
    1,191
    Carmichael, CA
    How about a low voltage pump and a mist system attached the to front bumper? You could replenish the snake oil as it blows off the car. :madgrin:
    Anybody see any potential issues with that plan? :madgrin:
  14. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Don't forget the goggles and scarf to wipe the oil from your face. Wait, I'm thinking the old caster oil aircraft engines that blew their oil out the exhaust.
  15. MrChristian
    MrChristian New Member
    31
    Washington
    K, this is just an update.
    I know it sounds hokey and some will argue it can hardly be considered "hard science" but on a recent episode of mythbusters (yeah, I know, I know) they managed to dimple a car so that fuel economy was improved.
    Mythbusters: Dimpled Car Video at YourDiscovery.com
    Don't know whether can infer that you'd get the same effect from the sheet of vinyl these guys are offering, but it's still an interesting result.
  16. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Variable spin control????
  17. Much More Better
    Much More Better Active Member
    655
    163
    Gives new meaning to the bumper sticker "I'd rather drive a Titleist"
