Fault code D1811
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tomek310, Oct 9, 2018.
  1. Tomek310
    Tomek310 Junior Member
    89
    Riverside
    Hi guys,
    I did not think that I would have to ask you for help, but I was wrong. I am getting the SRS light and this D1811 code. After doing some research I have determined I had a bad clock spring. I have ordered a brand new one, installed it, reset the code, but after cycling the power button the code comes back. I am just wondering if any of you had this code and how did you get it fixed. Thanks.
  2. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Do your buttons work on the steering wheel
  3. Patrick Wong
    18,210
    6,517
    "D1811" is not a valid DTC.
    Perhaps you meant B1811, and if so there are four possible fault areas. Instrument panel wire, spiral cable, horn button (SRS) assembly, or the airbag ECU. techinfo.toyota.com is a source of the factory repair manual info so that you can follow the troubleshooting tree.
    Raytheeagle likes this.
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    "Brand new" from who/what?
    A 100% genuine, OEM, and NEW, clock spring runs:
    $233.12 at Camelback Toyota (Phoenix, AZ),
    $219.74 at Conicelli Toyota (Conshohocken, PA)​
    FraudBay (eBay) has lots of counterfeit clocksprings. Many have installed these b/c of price appeal, but have had to redo the repair a year later. You get what you pay for. More importantly, will the fakes be able to deploy the steering wheel airbag? READ: Be careful of counterfeit Clocksprings / Spiral Cables sold online | PriusChat
    A genuine OEM clockspring is relatively expensive. The original clockspring's seem to last a REALLY LONG TIME. Your's likely lasted 12years. A genunie OEM replacement will likely outlast the car.
    Amortize a genunie OEM replacement over 12years, the part is CHEAP. $220/12years = $18.33/year (avoid Starbucks 3.5times a year, for the next 12years) = $1.53/month (no McDonald's cheesburger once a month, for the next 12years).
    #4 exstudent, Oct 10, 2018
