Faulty 12 volt battery + possibly nuked electricals
Discussion in 'Gen 5 Prius Main Forum' started by Uhcoustic, Feb 21, 2024.
  1. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    If reliability and supply issues persist with the Yuasa Calcium-Lead battery, I'd think seriously about putting in an AGM for about the same price. Here's one, unfortunately from New Zealand. Toyota Prius Hybrid battery LN1 AGM 345ln1-mf — Superstart Batteries
    Might be an adequate AGM available in North America - not sure.
  2. Mr.Vanvandenburg
    1,362
    667
    2020 Prius Prime
    Let’s see what you get, a Napa or Oreillys (old Kragen) is my bet. Nothing wrong with them.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,148
    6,988
    Texas Hill Country
    #43 rjparker, Feb 22, 2024
    Mendel Leisk and Uhcoustic like this.
  4. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Text above says "...flooded, lead acid 12V car battery. ..." then there's "a bit more" Text says "... calcium base superior MF battery ..."
    I read elesewhere 'MF' usually means Maintenance Free.
    so which is it, is it a flooded lead acid or a calcium base battery.
    The reason being that calcium silver batteries and lead acid batteries charge at different max voltages.
    Downrange likes this.
  5. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    No-one mentioned silver until you - you just switched chemistry.
    It seems to be lead-calcium-acid, which is "standard".
    Some of the text above may have come from this Facebook post by the manufacturer:
    Edit: okay, seems I can't post Facebook links - they get transformed into some sort of embed which doesn't work.
  6. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    Can you message me the facebook link ?
  7. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    I don't understand what you just posted.
    "It seems to be lead-calcium-acid, which is "standard""
    Do you mean that lead-calcium-acid is standard calcium battery ?
    Or that lead-calcium-acid is standard lead-acid battery ?
    I just noted the calcium-silver because I think I found some Yuasa calcium-silver batteries but no Yuasa lead-calcium-acid batteries.
  8. Gokhan
    Gokhan Senior Member
    6,718
    2,672
    Paramount CA
    To maintain the 12-V-battery health in my 2021 Prius Prime, I do all of the following:
    • Do regular long trips (which fully charges the battery)
    • Don't sit in the car unless it is in the READY mode (which drains the battery)
    • Don't leave the charger plugged in for longer than overnight (which drains the battery)
    Prius Prime electronics draw so much current that the 12-V battery will quickly drain if you sit in the car without the car being in the READY mode or if you keep leaving the charger plugged in for longer than overnight.
  9. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Let's try to skip the mangling - edit this:
    www facebook com GSYuasaHKG/posts/the-new-toyota-prius-equipped-with-the-gs-yuasa-345ln1-mf-the-original-fitment-a/1520256938120313/
    RandyPete likes this.
  10. Gokhan
    6,718
    2,672
    Paramount CA
    This is the factory battery. The dealer will install a Toyota TrueStart DIN H4 battery. Walmart sells EverStart Maxx BCI 140R and DIN H4 batteries (both equivalent to EN LN1). I have seen that the 140R EverStart Maxx has the correct exhaust-tube hole and plug. However, you want to have it replaced for free under warranty at the dealer. In any case, make sure that the battery comes with the exhaust hole and plug, as it will go into the trunk.
    GcinFl and Downrange like this.
  11. Downrange
    373
    214
    2024 Prius Prime
    SE
    Quite right. It's lead calcium and charges at a higher voltage. AGM batteries also charge at a slightly higher voltage than flooded batteries, but not as high (for a portion of the charging curve) as the calcium enhanced flooded batteries. It is a very good question: will the onboard charger damage an AGM battery due to over-voltage? This may be why the service protocol is so stringent. But the NZ company markets an AGM plug-and-play, so perhaps the small over-voltage is acceptable?
  12. Tooly
    Tooly Member
    51
    44
    Okanagan, BC
    2023 Prius Prime
    XSE
    Went and grabbed some pictures of the 12V in my 2023 Prime for those that are interested. You can see in the last picture the battery is vented with the tube running into a grommet on the floor.
    Gokhan likes this.
  13. Mendel Leisk
    42,381
    There seems to be a concept, that there's one battery that's 100% compatible. I've subscribed to that, presumed anything else would be some sort of generic, one-size-fits-all, sort of...
    Our son called one night, his civic wasn't starting, could I do a run to Canadian Tire, pick up their "compatible" battery. I did that, got to them, looked at the old and new batteries: apart from badges the batteries were near-identical, the same folding lift handles, edge molding, dimensions. Later on checking the specs, saw they were also near-identical
    Canadian Tire also carries a 3rd gen Prius battery, seems to be a similar story, has vent port, skinny posts, the same alpha/numeric moniker.
    Maybe battery compatibility issues are more prevalent with newer car models, at least till demand for replacement batteries increases?
  14. Gokhan
    6,718
    2,672
    Paramount CA
    Thanks for the nice pics. Does it have the plug on the opposite-side hole? Make sure you keep it when you replace the battery, in case the replacement battery is missing the plug.
  15. RandyPete
    409
    171
    2024 Prius Prime
    XSE
  16. Gokhan
    6,718
    2,672
    Paramount CA
    All modern 12-V batteries use lead–calcium plates:
    EXIDE batteries—Technical guide 2020
    AGM will probably work, but I would stick with a flooded one to be on the safe side. Also, again, make sure that the vent holes and a plug are present in the replacement battery. Walmart EverStart Maxx BCI 140R is a safe, solid choice and probably better than the OEM Yuasa EN LN1. It has a higher Ah capacity than the OEM, which will certainly help with the charge draining.
  17. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    I don't agree. The Batteries (2) in my 2005 F250 5.0L diesel pickup are 100% pure lead plates. Still avaliable today. The Brand is ODYSSEY. Many seek this brand battery out for use in diesle trucks and Jeeps. They are good batteries (the besst in my opinion) for heavy use and high starter cranking amps. They last for years. AGM battery.
    Gokhan likes this.
  18. Mr.Vanvandenburg
    1,362
    667
    2020 Prius Prime
    I noticed only the agm is for sale now at Oreillys.
    More things seen, the VW ID.4 takes the same battery. If it is made by Varta in Germany, if it has the vent, and is under $200, may be an option. Apparently this size fits quite a few cars.
    Ohmmu makes a lithium ion battery for the gen 4 and many others. Pricey, but light weight and may last a long time. Should fit the Gen 5? No vent needed.
    Taking long trips is no assurance the battery gets to 100%. This little battery discharges fast. My experience is a trip might not end with 100%. Have to have a battery monitor to know more. I externally charge to 100% often, and it doesn’t stay there 24 hours.
    So many still good hybrid 12 v probably going to recycling when they only need charging.
    BiomedO1 likes this.
  19. Gokhan
    6,718
    2,672
    Paramount CA
    I see. I didn't know Odyssey didn't use calcium. They are top-rated by Consumer Reports.
  20. Uhcoustic
    Uhcoustic Member
    55
    30
    2023 Prius Prime
    XSE
    Unfortunate update for you all - after applying the "new" battery, there are still a number of error codes. The service technician determined that the "main fuse on the junction block" was blown by the backwards jumpstart attempt. They cannot diagnose further until this part is replaced; there is likely to be other damage. Unfortunately, this is not covered by warranty, so it's on me to contact toyota or file an insurance claim with the towing company. Toyota ought to cover it, because they were contracted via Toyota Roadside, so we'll see. I'll call them tomorrow.
