faulty combination switch - high beams stuck - installation help
Discussion in 'Gen 2 Prius Technical Discussion' started by torpedo51, Apr 16, 2012.
  1. torpedo51
    torpedo51 New Member
    Carson City
    Headlight knob: rotated to OFF
    Headlight lever: LOWBEAM position
    Expected Results: headlights are completely off
    Actual results: headlights are completely off (OK)
    Headlight lever: pulled into FLASH TO PASS position
    Expected Results: highbeams on until lever is released
    Actual results: highbeams on until lever is released (OK)
    Headlight knob: rotated to ON
    Expected Results: lowbeams on
    Actual results: highbeams on (FAIL)
    I verified the relays are working correctly. I suspect the combination switch itself is faulty. I will check the pins on the relay panel with a voltmeter later to confirm that the combination switch is sending voltage to the high beam relay incorrectly.
    In the mean time, I've found a replacement combination switch (Standard CBS-1233). I may need installation instructions. Can anyone help me find a procedure or diagrams please?
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    It is a PITA in comparison to other makes. You have to pull the steering wheel, which means disconnecting 12V power and removing the airbag.. Instructions are about the same as for replacing the clockspring aka spiral cable.
