Favorite LED headlights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mkarolian, Mar 20, 2016.
  1. mkarolian
    mkarolian Junior Member
    56
    Boston, MA
  2. Zipsta
    Zipsta Member
    35
    39
    Inland Empire
    Which LED headlights did you settle with? I'm looking for LED headlights as well. Also, the link you provided says high beam, low beam, DRL, Fog lights. Which is it?
    Z.
  3. Tideland Prius
    16,684
    The link shows H11/H8 base so that's what you should be looking for (the bulb type, not what the description says). The Gen 3 uses H11s for low beams and foglights and 9005 for high beams.
  4. Zipsta
    Zipsta Member
    35
    39
    Inland Empire
    TP,
    Thanks for that info. Gonna needed when I switch out the lights.
    Z.
  5. ohdgj599
    ohdgj599 New Member
    2017 Tesla Model S
    they exceeded my "brightness" expectations. With the power cord coming out the side, it makes them a bit more low profile but be sure there's space behind your fogs for the cooling apparatus
