Feds to probe cause of runaway Prius in California
Discussion in 'Gen 2 Prius Main Forum' started by PRIUS007, Mar 9, 2010.
  1. Optimus
    Optimus Member
    260
    17
    "Visually checking the brake pads and rotor it was clearly visible that there was nothing left"
    A part of me wonders....
    Considering how easy it is to swap around brake pads, someone theoretically could remove them and either grind off the material, or put a "spent" set of pads back in.... Or, just plain neglect and failing to install new brake pads when needed....
  2. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    See, heres another thing that just isn't adding up. Automotive brakes are engineered and designed to stop the vehicle they are placed on for xx,xxx miles.
    I've worked with friends of mine that are into racing cars, (not modified Nascars or anything such as that) and I've seen them literally stand on the brakes so often and so long that the rotor is literally glowing red from heat.
    Those brake rotors and brake pads were no where near even close to being worn down to nothing.
    I don't have any idea how many miles were on this Prius to start with, but when I see all these pictures of Prius brakes that look almost new after 100,000 miles, I find it a tad bit interesting how these brakes were worn down to nothing. :confused:
  3. Optimus
    Optimus Member
    260
    17
    I agree. Our Prius (albeit a 1st generation) didn't need front pads until 125,000 miles. And the only reason I had to do them was because the car sat for a while (during the rainy season) and the front rotors rusted beyond being worth saving. It was easy enough just to swap out the pads and rotors, and was quite inexpensive.
  4. desertrider2215
    156
    usa
    Just heard the news conference and they reported that the brake pedal was pressed over 250+ times on his "wild ride" and that the break pattern wear was "on and off" braking.
    pretty sure he's in deep now.
  5. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Time to buy another Prius before the scare subsides.:D:D:D:D:D
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Eureka!
    This should please to no end those who have been long predicting the
    existence of a "smoking gun." Seems like it its last shot passed through
    the shooter's foot.
  7. PRIUS007
    133
    Mundelein, Illinois
    I have a feeling now that they have looked at the Prius, that they are now going to start looking at the people making these claims and see what's behind them.
    Apparently, they have been getting allot of 'hate' mail after this story and personally, I feel that if this is legit, he should take a polygraph test and at least get people off your back.
    If it really happened and there is nothing to hide, why not.
  8. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Yes, interesting how it wore to metal.Also, we need to understand thought that the Prius' brake pads and rotors are nowhere near what they are on race car. My wife's front pads, 96 Avalon had issues of coming apart practically before its time. But then, maybe she was riding them more than I would?:rolleyes:
  9. Walt999
    Walt999 New Member
    23
    New Mexico
    This is all well and good but you are forgetting two important facts:
    1. No matter if all electronics failed at the same time: there is a direct mechanical connection from the brake pedal to the hydraulic brake system. There would only be no power assist with dead electronics. You can still stop the car.
    2. The total engine power is nowhere near that of the braking power on the car. There isn't a car made that the brakes can't stop even with full throttle applied. It just takes more distance.
      Of course if you leave the garage with completely worn out brakes in the first place, then you can't stop, engine or no engine.
      Walt
  10. Tomel51
    Tomel51 Junior Member
    25
    Virginia
    I have a question for the experts monitoring this thread ( I hope it hasn't already been asked, but I didn't see it when I scanned the various replies).
    IF someone WANTED to "fake" a runaway Prius, how could it be done? It's been stated numerous times in this thread that the Prius has a failsafe interlock where pressure on the brake pedal cuts off acceleration. The police officer involved stated that he smelled the brakes "burning." If he smelled the brakes burning (that would appear to be hard to fake), it seems to imply that the driver DID have his foot on the brakes. If he did have his foot on the brake, then how did he keep the vehicle from slowing down. Which brings me back to my question, CAN it be faked? If so, how?
    Thanks.
  11. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    At the press conference on Monday, it was revealed that the log downloaded from the hybrid computer's diagnostic system in Sikes' Prius showed that the brake pedal and gas pedal were alternatingly engaged at lease 250 times. (the system logs the most recent 250 events).
    It would be a simple matter to try that on a test track and see what kind of brake pad wear results from it.
    Someone else in another thread also raised the possibility that Sikes might have been abusing his brake pads in this manner for days to wear them down before perpetrating that incident.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    If we ignore the options of tampering with the control system to directly operate the brakes, there are two easy ways to burn the brakes while moving:
    1) Hold down the accelerator pedal and press the brake, but keep the brake pressure below the brake override threshold (about 50%).
    2) Alternate between acceleration and braking. To force friction braking, shift to N for each braking cycle. Braking with shifting to N will also work once the HV battery charges to the high limit.
    Tom
  13. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    I am more interested in a run-away congress. No brakes there.
  14. qbee42
    18,058
    3,074
    Northern Michigan
    If we could just point them at the sea. ;)
    Tom
  15. dogfriend
    7,512
    1,185
    Carmichael, CA
    Tell them the lobbyists are waiting at the shoreline. :madgrin:
  16. swi66
    swi66 Member
    193
    Gasport, NY
    Just an aside.
    My wife has a 200 Jeep Cherokee, postal version. Also a 1998 Subaru Postal.
    She is a mail carrier, and makes 600 stops a day on average.
    She wears out a set of brakes in 6000 miles.
    I do all the brake work.
    Yes she overheats brakes!
    Makes the rotors red hot too.
    Brakes getting that hot can and will boil brake fluid, leaving a spongy pedal afterewards until they are bled.
    She has also dried out the rubber piston seals in the calipers to where they have blown. Calipers only last her a year or so due to the heat.
    Everything everywhere is covered in brake dust.
    If this guy really burnt out the brakes, there would be evidence...........
  17. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    My question for those in the know is how long of a readout by time was this: 1minute, 10 minutes, since it was started?
  18. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    There is no doubt that the brakes were expended. Only question is why he purposely did it.
  19. qbee42
    18,058
    3,074
    Northern Michigan
    We don't know for sure. The limited information that we have suggests that the count gets reset after each boot. If this is true, it would be for the entire previous trip.
    Tom
