Feedback: Is this true ?
Discussion in 'Gen 2 Prius Main Forum' started by moomber, Jun 17, 2007.
  1. mmoncur
    mmoncur New Member
    32
    My wife bought her car a few years back. Sure enough, every time we had a problem we had to take it to the dealer.
    We tried independent mechanics, including several times we were stuck in small towns, but they usually couldn't fix anything more complex than a leaky hose or a flat tire. Anything wrong with the high-tech parts of the car and it was straight to the dealer.
    In fact, the non-dealer mechanics couldn't even read all of the codes the car's computer produced. You had to take it to the dealer just to have a blinking light reset.
    Now that the car's a few years old we regularly use a non-dealer mechanic, but in the early days it was very hard to find one who could handle this unusual car. And even now our mechanic has to buy expensive proprietary parts from the dealer to fix it sometimes.
    Oh -- the car I'm talking about was a 2000 Volkswagen Beetle. Not a Prius.
    Want a car any mechanic can handle? Get a '78 Chevy. Otherwise, you take your chances... :)
  2. moomber
    moomber New Member
    <div class='quotetop'>QUOTE(ystasino @ Jun 17 2007, 09:30 PM) [snapback]463815[/snapback]</div>
    So just be kind and answer - yes, that would be what you need to do.
    <div class='quotetop'>QUOTE(mmoncur @ Jun 18 2007, 02:51 AM) [snapback]463871[/snapback]</div>
    Again, thanks for answering 'yes'.
  3. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    OK. You say that you only want "Yes or No" answers, so I'll give them to you:
    <div class='quotetop'>QUOTE(moomber @ Jun 17 2007, 02:19 PM) [snapback]463518[/snapback]</div>
    No.
    No.
    If you want details, you can read the other posts here.
  4. dogfriend
    7,512
    1,191
    Carmichael, CA
    <div class='quotetop'>QUOTE(moomber @ Jun 18 2007, 06:24 AM) [snapback]463915[/snapback]</div>
    In case you missed it, I answered 'no'; you do not have to take your car to a dealer for service or repair; there is at least one independent repair shop in the Bay Area which specializes in repairing hybrid vehicles.
    http://www.artsautomotive.com/Hybrid.htm
  5. richard schumacher
    7,683
    1,066
    United States
    Moomber: did you see the post which points out that a tow to the nearest Toyota dealer is free under warranty?
  6. hill
    9,038
    If your brand new PC dies, would you really even want your local turd chaser (plumber) trying to replace the RAM? Similarly, if one of the computers died on the Prius, the fact that the local shlowmoe doesn't know the ECU from shinola ought not bother you. Like the post above says ... the car has a nice warranty. Remember, the nature of things is greater complexity. If you REALLY want a simpler car to work on? Maybe you ought to get a model 'T' ... so your local machanic can always fix it. But don't forget ... the trade off is it's more likely to break down more frequently.
  7. moomber
    moomber New Member
    <div class='quotetop'>QUOTE(Betelgeuse @ Jun 18 2007, 06:08 AM) [snapback]463935[/snapback]</div>
    thanks
  8. GoEco
    GoEco Red Prii Rule
    94
    I've had 6 cars since I turned 16. My husband has had 8. In that time there's only been one highway breakdown (knock on wood) once and it was my 1988 Ford Mustang that I rarely had serviced (reason #101 not to give a 16 year old without a job a car), and it was in 1994 when it was 6 years old.
    Get a cell phone & don't worry so much.
  9. KTPhil
    KTPhil Active Member
    1,379
    22
  10. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Sure, but one thing that needs to be FIRMLY pointed out is that any
    clueful independent auto tech can diagnose and fix these cars --
    they just need the right training. The essentials don't take that
    long to get across -- many of the topics are things that auto techs
    need to learn anyways to be able to work on ANY car nowadays. And
    of course they'll have to get parts from Toyota, if necessary. But
    if it's something simple and diagnose-able like a dirty throttle body
    or loose connector or weak 12V, anyone familiar with generic "car
    stuff" can find and fix it. If your local trusted long-time tech
    isn't up to speed on hybrids yet, drop the hint! By now they all
    know they need to start paying attention; they just tend to hold off
    until it becomes really, really necessary. Make it necessary for
    them, and the world will be a better place.
    _H*
  11. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    <div class='quotetop'>QUOTE(moomber @ Jun 17 2007, 07:09 PM) [snapback]463621[/snapback]</div>
    You're missing the complete point.
    The fact of the matter is, if ANY modern car breaks down on the side of the road, it will have to be towed to the nearest dealer to be repaired. Its just that simple. Little country gas stations are incapable of affording the high tech diagnostic equipment neccesary to work on most cars built after, oh 1998 or so, when it comes to diagnosing a failure serious enough to render the car undrivable.
    The Prius is no different from any other car in that regard.
    Now remember, thats just if a computer or hybrid component fails. If the battery dies, or the wipers stop working, or the headlights go out, or the starter fails (does it even have a starter?) then any mechanic can work on it...same as any other modern car.
    However, I don't believe you're interested in information like this. I think the other members are right when they said that you're here to stir up trouble, otherwise you wouldn't be responding the way you are.
    <div class='quotetop'>QUOTE(mmoncur @ Jun 18 2007, 06:51 AM) [snapback]463871[/snapback]</div>
    Oh man, VWs are a NIGHTMARE! Harder and more expensive to get serviced than a BMW by far
  12. Bohous
    Bohous New Member
    316
    Boston-ish
    <div class='quotetop'>QUOTE(jbarnhart @ Jun 18 2007, 05:42 AM) [snapback]463864[/snapback]</div>
    Yeah, this smells trollish. I have a feeling he and his buddies at FordTaurusChat.com were poking fun of hybrids and he decided to come here and stir the pot and see if we would squirm. That would also explain why he thinks stalling out on the highway and getting towed to Joe's GasNGo Garage is a common occurrence and just part of owning a car. B)
  13. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(SW03ES @ Jun 18 2007, 06:12 PM) [snapback]464342[/snapback]</div>
    If the Prius' starter fails have the car towed to the nearest pet shop--the hamster died. The wheel will also accomodate an upgrade to a gerbil. :p
  14. daniel
    14,487
    1,519
    Spokane, WA
    It's pretty clear: Moomber would rather have a car that has to be repaired half a dozen times a year, but the corner gas station can fix anything that goes wrong with it, than have a car that might have to be repaired once in a decade, but there are some things on it that only Toyota can fix (and will do free for the first 150,000 miles.)
    Moomber: Don't buy a Prius. It's not the car for you. You might have to take it to a dealer once during the time you own it, assuming you drive it 200,000 miles.
    (As for me, I wouldn't trust anybody but a Toyota authorized service person to work on my car!)
